Question about Estate Washing Machines
Estate washer etw4400sq0
Installation instructions
3 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Estate washer ETW4400SQ0 water runs, but does not fill completely
The water inlet valve sticks open at times because of sediment in the water. Disconnect the water and flush it out and clean the screen filter where it connects to the inlet valve. It's probablly just the cold water side sticking.
Posted on Jul 08, 2009
  • 45079 Answers
SOURCE: Estate by Whirlpool washing machine Model:etw4400sq0 not spinning.
In my experience, a failed coupling is a likely cause
Posted on Dec 26, 2012
How would estate whirlpool washer etw4400sq0 and every time it goes into spin cycle it is off balance and dances across the floor
When it first came to your house and you unpacked it would have been held in place with packing bolts to stabilise it. The bolts would be located at the back of the machine you probably have 4 bolts, you will find them two at the top and two at the bottom holding the drum in place check to see it the bolts have been removed if not remove them and it will be fine
Aug 08, 2014 | Whirlpool Washing Machines
Dec 26, 2012 | Estate Washing Machines
M/N ETW4400SQ0 The small pin, 2" with cotter pin hole in the end, underneath the machine, with a opaque capture shield has come loose from the spring it holds? In turn during spin cycle the...
Hello Mike
Those cotter pins with the shield over them were part of the shipping braces from when it left the factory and they do have no bearing on the suspension system.
What most likely thats causing it to vibrate so badly are the cresent shaped plastic peices that fit between the plates under the outer tub,Their is 2 types of those on the washer one fits under the bottom plate and one fits on the top of the bottom plate andin between the upper and lower plate. They are impregnated with teflon and have worn out so instead of the plates sliding free the are grinding against each other
Those parts are called suspension pads,the part number for them is 285744 &285219 they can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
This link shows where they are they are item numbers 13&15
http://www.searspartsdirect.com/partsdirect/part-model/Estate-Parts/Washer-Parts/Model-ETW4400SQ0/3191/0153200/W0607071/00005?blt=06&prst=0&shdMod=ETW4400SQ0
GENE
Sep 24, 2011 | Whirlpool Washing Machines
Jul 08, 2009 | Washing Machines
I need to install a coupling into my washer. hows that done?
easy enough repair, you can get a video instruction fom you tube, search,, motor coupling whirlpool washer. take you all of 20 min!!!!!
Jan 10, 2009 | Estate TAWS800JQ Top Load Washer
Washer smells after load
First thing to try is to get affresh washer tablets. They are a new product from whirlpool designed for front loaders to keep the smell out. They also work great for top loading machines. They are about ten dollars a pack. Read the instructions and run the washer through its cycle and the smell get better. The longer you use it, the smell should go away.
Nov 17, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate top loading washer needs a lid switch replacement
I found one one NEW on ebay for 6.50 + shipping, total 12.49. Other parts places had them for a lot more. It wasn't too hard to install.
Nov 06, 2008 | Estate TAWS800JQ Top Load Washer
Washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge instead......estate washers are horrible
Mar 20, 2008 | Estate TAWX700JQ Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
22 people viewed this question
Top Estate Washing Machines Experts
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
