Question about HP PSC 1610v All-in-One Printer
How do i use scanner do i need a disk - HP PSC 1610v All-in-One Printer
  • 52 Answers
Yes! you must install the scanner's driver for you to be able to use the scanner..
Posted on Jan 22, 2009
NEED SCANSNAP 1500 DISK NEW SCANNER DISK IS LOST
don't know if you ever got this resolved but....
http://www.fujitsu.com/global/support/computing/peripheral/scanners/software/s1500.html
check under the operating system tab to select the right installer for you.
Mar 23, 2013 | Fujitsu ScanSnap Manager
Fujitsu 6130 Scanner speed has gone down considerably
Scanner speeds are dependent on the Computer System and the hard disk capacity. You need to create contiguous and Large space in Hard disk. Delete unwanted files and also run 'disk defragment' to create contiguous space.
S. Mohan, Chennai, India
Aug 30, 2011 | Fujitsu fi-6130 Flatbed Scanner
Its cannot scan or detect
You need to reinstall the scanner driver in your computer.
Uninstall scanner driver first then if you have scanner driver disk then you can install it fro that disk.
Give me your scanner information so i can give you url for download drivers or your scanner.
Feb 11, 2010 | Acer TravelMate 6291-6753 Notebook
I purchased my Microtek ScanMaker 3800 many years ago. I still have the installation CD. Recently I purchased an HP laptop running Vista. My question: is it all right to plug in the scanner directly...
First connect your scanner to computer with usb cable.
Then insert disk in rom then install driver and software from disk.
It is not matter that first you connect scanner or install driver but if you connect scanner first your computer recognized it then you can install driver from disk.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 13, 2010 | Microtek Computers & Internet
Do i need more than just the drivers installed in order for the scanner to work? ie. Do I need the kodak software?
You will need the install disk to have your copier, scanner, etc to work properly\
You can contact the manufacturer for the installation disk or re install using the disk provided with the unit.
this should restore the scanner operation if you have lost that function.
2. check the user's manual for specific instruction on the scanner usage.
Jan 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My new Dell laptop won't accept my old BenQ flatbed scanner Model no. 6678-9BU.
Many scanners are not compatible with new windows versions, probably the scanner does not work on Vista.
You need to find, download and install the driver for your scanner, if you have the original disk, try using athe disk.
Here is direct link to download . Register with the website first(Create a new account), then download from here:6678 driver (Benq)
If the disk does not install, or you find no drivers, that means the scanner is not compatible with your new system.
Oct 10, 2008 | BenQ Office Equipment & Supplies
Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
HP PSC 1610v All-in-One Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
