Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Sony 46in hdtv picture and color has triple vision
I tried messing with the convergance that didnt help at all i looked at all the curcuit boards and nothins burnt out i have ran out of ideas and really need someones help thanks
  • Joe1974 May 11, 2010
    Sounds like a convergence problem as Ecullier2012 and Wayne mentioned. I don't know why you gave him an inappropriate rating, I think he gave appropriate advice to what you were describing. If this doesn't sound like the problem then please leave more info of the symptoms. I can tell you that the site that Jean posted will not fix this
    problem and could even make things worse. That site pertains to a specific problem that is common in
    some Sony sets and should not be used to try to fix any other issue.
    Please keep in mind many things can go wrong with TV
    sets and you should really do a lot of research before attempting any
    adjustment and or repair. There are high voltages present in some areas and they can
    reside even when the set is unplugged.
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Don't spend any money yet, hope you haven't already !
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
I had the EXACT same problem, also a Sony ( this blog covers many
makes and models).... Had it fixed in 10 minutes....took me 5 minutes just
to find my screwdriver..*lol*
Give it a try, it's free and simple :D
Posted on Mar 12, 2009
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directisony 46in hdtv picture and color has triple vision - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6sony 46in hdtv picture and color has triple vision - 2c07611.pngs=
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 28, 2009
    Novelist:
    Scholar:
  • 67 Answers
On this model, there wouldn't be any signs of damage on the boards that are visible. There are mini fuses (picofuses) that protect the power supply from damage if there is a short in the convergence I.C.s.
There are two types of convergence issues. One is if the colors are shifted from side to side, like the reds are farther right from everything else, but otherwise, the picture fills up the screen from top to bottom, and from left to right, it is probably a convergence driver issue. If the picture droops from the top and bows up from the bottom, it is a pincushion problem that can be a bit difficult to track.
I recommend taking this TV to an authorized servicer. The last D board I replaced about 2 months ago for this set was actually still available from Sony, and it had a price of $125.00. That, combined with labor, should be cost effective enough to repair the set.
I hope this helps you...
Posted on Jan 22, 2009
Why is the picture like double vision blurry?
The tv have a problems known as a convergence problems,it dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board will solved the tv convergence pictictue problems.The shop,will cost u like $300-350 for parts and labors.
Feb 24, 2011 | Hitachi 51F500 51" Rear Projection...
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
Seeing triple images of everything
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignmenents,have colors shadows or 3D pictures look alike?The tv convergence board have dead 2 STK Convergence ICS and some or all of it resistors too.These parts on the convergence board must be replaced to fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 03, 2011 | Sony KP-57WS500 57" Rear Projection...
Left and right sides, seeing triples in three colors,but the center is fine?
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have picture colors shadows or 3D picture look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 08, 2010 | Mitsubishi WS-55315 55" Rear Projection...
My sony kp57ws510 model tv has double vision and the double vision that shouldnt be there is in blue and red..whats wrong with my tv?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors on the tv convergence board are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a samsung 65in hdtv rear projection and the colors dont line up it looks like triple vision what could it be
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Samsung HCN653W 65" Rear Projection...
Double vision
I have a 60SBX72B and the colors are all separated like triple vision. Is there a way that I could fix this
Jan 07, 2010 | Hitachi 50UX57B 50" Rear Projection...
Red and Yellow blurred picture
I had the same problem this week. I tried the convergence thing but it was impossible to fix. I still needed the repairman. He changed two convergence units ($325, parts and labor). Then the tv was still doing the same thing. We had to adjust the convergence and now everything is perfect. You will need your converter
Mar 01, 2009 | Akai PTH5498 54" Rear Projection...
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
The Picture
All my colours are swirving all over the place
Dec 27, 2007 | Samsung HCN4226W 42" Rear Projection...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
