Question about Magic Protechnic 80mm Sleeve Bearing Case Cooling Fan - CASE FAN Case Cooling Fan, Fan Kit, Cooling Fan
I need a replacement fan for a Protechnic Magic MGA9212UB-025. This is not for a computer, but thought someone might have an idea.
This fan is for a RV Dometic 1402 refrigerator. It is used to cool the external condenser.
2 Suggested Answers
mattrubin
  • 161 Answers
SOURCE: I have a Protechnic MAGIC CPU Fan, MGT7012UR-015 ,
its a standard 80mm fan. You dont need one by that company as its a interchangeable part.
any of these will work
http://www.frozencpu.com/cat/l3/g36/c15/s58/gallery/p1/Fans-12_Volt_Fans-80mm_x_25mm_Fans-Page1.html
any of these will too
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=+40000573&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&Subcategory=-1&description=80+mm+fan&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
Posted on Apr 06, 2010
Have a Magic chef MCWC50DST that the compressor and fan wont start. I thought it was the ptc starter which I replaced and that didn't fix it. The circuit board and controller are getting power as the light...
are u saying u replaced the start relay? and capacitor? I would check the cold control thermostat as if its defective u will get no fan no compressor etc. u can also check the compressor itself by removing the relay and capacitor then using a multi meter to measure the run and start windings for ohms, measure separately then together and the reading u get when together should equal the readings of both separate measurements? give or take 5 percent. u test by connecting the multimeter prongs to the nutual and the run and the nutrul ( center prong) and the start prongs
Mar 12, 2015 | Magic Chef Refrigerators
MCO153UWT shutting down after 3.5 minutes
it is an internal fan that is the problems, if this is a counter top MW just replace it. if Over The Range (OTR) and under warranty call for service. if out of warranty replace.
Jan 23, 2012 | Magic Chef Microwave Ovens
I have a Protechnic MAGIC CPU Fan, MGT7012UR-015 , 12v, 0.58A in my Acer PC. The manufacture date is 2007/8/28. It has started making a whining sound so I need a replacement. True to form, the warranty...
Feb 19, 2010 | Magic Protechnic 80mm Sleeve Bearing Case...
I need a replacement fan for my medion computer the part# is cI5-9hdpb-m2 / mgt921ur-w25
You can use any generic 80mm fan, many local computer stores usually have a selection available.
Sep 30, 2009 | Magic Protechnic 80mm Sleeve Bearing Case...
New Video card cooling
I would highly reccomend paying for an aftermarket heatsink insted of playing too much with additional fans on the graphics card. While bigger fans make small difference, a bigger better heatsink, with higher quality/conductivity contact material (copper) makes a HUGE difference. Also the way the heatsink contacts the processor on the graphics card is very important, thousands of PC modders apply "Artic Silver 5" to the bottom of the graphics card heatsinks(where it contacts the processor) and have large drops in temperatures. The compound costs about five to ten dollars, and most neighborhood radioshacks have it in stock.
If your interested in getting a new heatsink: (See GPU heatinks at newegg.com)
Just make sure its compatible with your particular card.
May 14, 2009 | HP Pavilion a705w PC Desktop
I dont know how to hook the vent fan for outside on the Magic Chef CMV1000B?
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
For Magic Chef in Canada call 866.587.2002
Dec 05, 2008 | Magic Chef CMV1000B Microwave Oven
Replacement Fan And Heat Sink For 500 GR
Remove the heat sink and fan, take it to any computer shop and they will give you compatible replacements
May 17, 2008 | Gateway 500GR PC Desktop
My Fujitsu Siemens Scaleo P tower fails to boot up, sometimes shuts down after a few seconds, no output to monitor. Can you help
I also have a Fujitsu-Scaleo P, yesterday I had the same problem exactly as described here. The issue is that the CPU fan does not work anymore. It is easy to replace, only four Phillips screws to be removed. I simply don't know if the new fan replacement can be bought alone, or if the air duct will be in the replacement kit, along with the aluminum block. It is a Cooler Master Model made by Protechnic Electric model MGT 9212ZR-W25. If it wasn't that the problem, when the computer is still cold, try to boot it, press DEL which will bring up the BIOS Setup Menu, and you can see if the Fan still works: in one of its menus shows the Fan RPMs and CPU Core Temperature. Good luck.
Mar 31, 2008 | Computers & Internet
Why did I buy it Magic Chef problem
of course replace the fan some times they go bad some times defective it happens seen them bad brand new out of the box
Feb 16, 2008 | Refrigerators
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Computers & Internet Logo
193 people viewed this question
Top Magic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
ctlimey
Level 1 Expert
Are you a Magic Computer and Internet Expert? Answer questions, earn points and help others
