Question about Kenmore 47153 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Stove beeping and error F11
My range started beeping and the error message F11 appeared. The beeping would not stop until I unplugged the stove and then plugged it back in. Also, all the burners are sparking when I turn one burner on. Is this usual, I did not ever notice it before?
  • cplutterfly May 11, 2009
    I have the same problem with my Kenmore elite slide in range. It gives the F11 error and the beeping won't stop.
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Mar 22, 2008 | Jenn-Air JES8750 Electric Kitchen Range
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Beeping won't stop and the F7 error code appears on the monitor
You may have got water into the control panel or cooktop causing an electrical short. Hopefully if you give a few days to dry out and plug it back in the code will be gone.
Sep 10, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Error message FSEO appear on display of whirlpool stove
Door and switches
do not agree
1. Unplug range or disconnect power.
2. Check wires and connectors from control to door switch, then from door switch to control.
3. If no damage to wires or connectors, replace door switch.
4. Replace all parts and panels before operating.
5. Plug in range or reconnect power.
6. Press Cancel/OFF key. Program and start the CLEAN mode, and observe for 1 minute to ensure that
operation is normal.
7. Go to step 1 and complete checks.
Jan 11, 2009 | Whirlpool RF364 Electric Kitchen Range
Stove stays on and 30 min. later it starts beeping and F1 code
An F1 error code indicates a faulty keypad and /or ERC electronic control.
Jan 02, 2009 | Frigidaire FEF366 Electric Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
Maytag gemini f1-9 error
plug it back in and press the cancel button
Mar 31, 2008 | Maytag MER6772 Gemini Electric Kitchen...
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kenmore 47153 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
1,162 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
