Question about E-Machines T6528 PC Desktop
Emachine T6528 problem: My monitor wont boot up went i start the computer!
My sister recently moved her computer to her new house. When she got here she tried to set up her computer. When she started her computer the monitor didn't boot-up with the computer. So today i thought i could by-pass the on-board monitor port, with a PCI graphics card to my dismay it didnt work. Is the computer just broke or is there something i can do about it.
  • 32 Answers
Easiest solution is to connect your monitor to another PC, if still nothing, then your monitor is toast.
If you are getting no display at all, and you tried a PCI video card and the onboard, most likely it is your monitor.
This is going to sound really dumb, but just incase, check to make sure both cables are snug in the monitor, I get calls daily at work with people telling me their monitor has died, only to find out that the power cord in the rear or the monitor is not completely snug.
Posted on Jan 25, 2009
When turning on my emachine desktop the monitor states no signal someone suggested that I need a fuse, Where would that fuse be located?
hello if the monitor wanted a fuse .. then it wont turn on.. which means its getting power !!!
you problem is the pc ,or monitor cable fell out at the back of pc, or you may have a defective memory stick ,that if the pc is getting power and you are seeing light on the pc.. if the pc is dead nothing lighting.. no beeps, not even the optical not opening then you have a power supply problem,
if u had a surge be it went dead try this, unplug system for 5 mins, the plug it back in, try powering on.. if still nothing , most likely , memory,video card or power supply is defective, but i think. its your memory if getting power
Jan 22, 2011 | E-Machines T6528 PC Desktop
How do to change the boot order in a emachine t6528
When the machine are start to boot press F2 before start windows, That is the setup of the Bios and there you can change the boot order
Dec 29, 2010 | E-Machines T6528 PC Desktop
Im trying to install a new video card on an emachine and i keep getting a no signal input on the monitor. thats what i started with.
Is the new video card compatible with your motherboard?If it is , can you try connecting your monitor VGA Cable from your video card properly?
And also if you are using a PCI Video Card you should try to install it to another slot if theres an instance that a PCI Slot doesnt work.
Jan 07, 2010 | E-Machines T6528 PC Desktop
Have emachines T6528 graphics problem
if it doesn't boot at all .( this is the reason that you see that message on the screen it means that no video signal came out from the computer ) ..try to change the cable that leads from the pc to the monitor first ...and if the problem its still on ...it have to be something related with the Ram memory or the CPU ....cause these 2 are the only things that can make a system to do not boot at all ...if any other device will not work ..the pc will still boot to bios ..or will still show the devices it finds on start ...even if is not able to succeed with the operating system boot...
so ...either it boots and you can not see anything cause the cable its damaged...( very possible cause this is the case it shows that message ...when the cable its shorted ..or unplugged ) or it doesn't starts at all cause of the memory or CPU ...
Sep 08, 2009 | E-Machines T6528 PC Desktop
EMachine W3107 will not boot, no display.
Have you tried a different Graphics Card, looks to me like the onboard graphics card is at fault, there should be an AGP slot or PCI slot that you can plug a new Graphics card into then you should be fine...
Sep 04, 2009 | Computers & Internet
Weird blink problem...
That's definitely a hardware (incompatiblity) problem. Download the most updated driver for the graphics card. Also see if there is a monitor driver for the monitor.
I understand it worked seamlessly for the emachine but you should switch it back for a day or two to rule out the monitor just screwing up.
Mar 11, 2008 | E-Machines eMachines Monitor E15T4
EMachine Help
If you took the pc in to a repair shop and they diagnosed that as the problem. You will have to install the new vieo adapter in the computer. Then plug in the monitor to see something on the screen. You can go into the bios to disable the other. Now if you are going by hear say and an actual tech did not check your system it does not necessarily have to be the video adapter at fault. You will need to have it checked out to validate that. Now if you did install the card you will have to plug the monitor in the new adapter. If the problem is still there you have another issue with the pc. Please comment on what the case may be. I would be able to better help you.
Hope this helps you
Oct 20, 2007 | E-Machines T6528 PC Desktop
E-Machines T6528 PC Desktop Logo
228 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
