Question about Stoves 800DFDOm Dual Fuel (Electric and Gas) Kitchen Range
What oven cleaner can i use or is it self cleaning
If I used chemical cleaner and rinsed it out well - can I chance on self cleaning
I use easyoff oven cleaner all the time on our self cleaning oven , never had a problem.as I do not like self cleaning systems as they waste lots of electric . getting as hot as they do .
Aug 01, 2016 | Ovens
Turkey grease in oven, cleaned up excess liquid in oven tired to clean oven but fire started because of the grease. Can I use an oven cleaner to solve my problem?
Check out Easy Off Oven Cleaner. They make a special one for self cleaning ovens that won't hurt the self cleaning part of the stove. Just use small amounts at the time.
Nov 26, 2010 | GE Dishwashers
Can I use oven cleaner in a self cleaning oven cause the door will not lock to self clean it?
Yes, and it is way better to clean them the old fashioned way with cleaner and elbow grease...
heatman101
Oct 26, 2010 | Equipex PZ-330 Electric Single Oven
What type of oven cleaner can be used on the ge profile self cleaning ovens.
No chemical cleaners should be used on self cleaning ovens. Scrape the heavy soil with a plastic spatula and use the self clean feature. Once chemicals are used it will not clean satisfactorily again. Sorry..... Eric
Aug 17, 2010 | GE Ovens
I have never used a self cleaning oven.i have already put oven cleaner on the inside and let it stand for awhile is this right? god I don't want to blow up
You DO NOT use a oven cleaner with a self cleaning cycle. Wipe out the oven cleaner as instructed on the can. Oven cleaner is better than self clean cycles anyway. Most self clean cycles eventually cause oven control problems.
Oct 08, 2009 | GE JGRP20 Gas Single Oven
I have an electric Maytag stove/oven but don't know how to use the self cleaning feature. What do I do?
Dear cooper1914,
There are two types of Ovens that clean themselves.
1) A Self-Cleaning Oven which usually gets locked 1st then set on Self-Clean.
2) A Continuous-Cleaning Oven which is constantly cleaning
Some people prefer the old fashion clean by hand with degreasers but I prefer Self-Clean or Continuous-Clean as there is no need for harsh potent cleaners!
If you have a Self-Cleaning or Continuous-Clean Oven Do Not Clean With Cleaners as it will ruin the flavor of your oven!
Click on the following link for more info @ http://www.essortment.com/all/cleanoven_rbad.htm
Maytag Customer Support Manuals @ http://www.maytag.com/support/manuals_literature.jsp
jackiaria
Tuesday 02-24-2009 11:13am EST (USA)
Feb 24, 2009 | Maytag CWG3600A Gas Single Oven
Inside the oven door there are some stains from liquid spill that went through the vent, how can I clean it.
If your oven is self-cleaning, consult the owner's manual for instructions on how to use this feature. The self-cleaning feature works by heating the interior of the oven to a temperature so hot that it incinerates the residue inside the oven. Normally, it is not a good idea to clean the interior of a self-cleaning oven with a spray cleaner; however, refer to your owner's manual or contact the manufacturer of your oven for further information.
To clean a non-self-cleaning oven, use one of the many oven cleaners that are available at grocery and hardware stores.
May 04, 2008 | Kitchen Ranges
Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
Hotpoint self-cleaning oven
  I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
Oct 24, 2007 | Hotpoint RB757 Electric Kitchen Range
Stoves 800DFDOm Dual Fuel (Electric and Gas) Kitchen Range Logo
16 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
