Question about Yahoo Diamond Vision DVDC803-04 DVD Player
Change language on DVP-SR210P Sony DVD player
Orion tv code for sony dvp-sr210p dvd universal remote ?
You have this backwards; codes are in the remote. Use code search to find something that controls some or all functions of your Orion TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Aug 02, 2016 | Sony Televison & Video
I need the code for my Sony DVD player model DVP-SR210P. If you can help thanks
Could be one of seven codes, so try each until one works.
20533, 21533, 20864, 21033, 21070, 21431, 21536.
One of these should work if set-up directions are followed correctly.
Apr 25, 2016 | Sony Televison & Video
How to program my vizio universal remote to my sony dvp-sr210p dvd player
Try these codes. One should work.
Aug 22, 2015 | Sony Televison & Video
How do I connect a Sony DVD DVP-SR210P to a Scientific Atlanta Explorer 4240 HDC and a Sylvania TV C320SLX?
I am not sure you can connect your DVD player to your cable box. You should be able to connect both your cable box and DVD player to your TV set with two HDMI cables. This link is a pdf_usecares file of the TV manual that shows how to hook up your dad and cable box.
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0902617.pdf
Hope this helps.
Bob
Jan 04, 2015 | Sony DVP-SR210P Progressive Scan DVD...
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
Sony dvp sr210p
Press DISPLAY. Select the toolbox. Select the second item. From here the first item sets the screen language, the second item sets the menu language.
Jul 17, 2013 | Televison & Video
How do i connect my sony dvp-sr210p cd/dvd player to t.v.
you can use an RCA connector .just hooked up the rca cable in the video and audio port ( output ) of the dvd player and then the other end of the rca cable to the component input of the tv unit. then set the tv unit to the right input like AV1, AV2 or AV3. depending on the input that you have been plugged in the tv component input port.
Jun 25, 2012 | Televison & Video
Yahoo Diamond Vision DVDC803-04 DVD Player Logo
91 people viewed this question
Top Yahoo Televison & Video Experts
Henry  Thomas
Henry Thomas
richie46
Are you a Yahoo Televison and Video Expert? Answer questions, earn points and help others
