Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Oil leaking from green bulb housing
I have a SD-P4681 and there is oil leaking from the green bulb housing. Is this an easy fix or does the whole light fixture need to be replaced?
    Problem Solver:
  • 8 Answers
Sound's like bulb is going I have a complete set for your tv all set up all you need to do is bolt it in hook up the wires I saved them from my daughters tv when her audio viedo card burnt out $489.00 they want for the card to much money so I striped it I wish I would have saved the screen that's what I need but if you want the bulb set up ready to install you can have for $50.00 rocky
Posted on Jan 24, 2009
  • rocky_dog316 Jan 24, 2009
    sorry I forgot ph# 519 971 9408 if you want the bulb set up thanx rocky
Oil leak in 99 vw passat oil filter housing
Its a pretty easy fix with a litttle mechanical ability. Just remove filter,remove filter base/ oil cooler, replace gasket
Mar 04, 2014 | 1999 Volkswagen Passat
Oil cooler leak
I do not really see the problem here. If you found the leak then it is pretty easy to fix. I do not know if the oil cooler seal is available separately. Most of the time the Mazda dealer only sells the seal with the oil cooler and that is pretty expensive.
Jan 12, 2014 | 2006 Mazda 5
I can't get my tv to turn on. I turn it on and the green light comes on 3 times and the light only stays on for 3 seconds and then turns off. Can't get anything to happen with screen. Can you help me
Does it sound like it's coming on then powers down? Mine turned out to be the bulb. I bought a bulb on Ebay for less than $90.00 and installed it myself.
The bulb was inside a square metal housing, pull housing and bulb out of tv, replace the bulb reusing the existing housing, then replace..... Pretty easy fix, and I'm not all that mechanically inclined. Good luck!
Apr 05, 2013 | Televison & Video
I replaced my lamp on Saturday. Now my TV has a blinking green light and is not responsive. I tried to use the system reset button and that is not working either. I tried unplugging the TV overnight to...
Well you haven''t said what caused you to replace the lamp. But If the TV just went out and you thought it was the lamp dont throw away the old lamp yet. You have the "Green Blinking Light Of Death". First I would tell you to place the new bulb in the old housing. I have found that many of the Ebay replacement bulb housings just dont seat too well. Make sure to wear a golve to prevent getting any oil on the lamp. It an easy swap. Swap the bulbs and do a reset. If that does not fix it the Google "Mitsubishi GBLOD" tons of info oout there. If you are thinking of repairing it yourself ( I have fixed 2 myelf) Email pds318@frontier.com and ask for the repair info for the Mitsubishi 52525 He has a great libary of info he can send you and does it all for just donations.
Nov 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Hi. Jeep Liberty Diesel/ 2.8l 2006. Vehicle will stall upon initial start up after idling a few seconds. Will re-fire after primer bulb is pumped in water seperator. Leaque?. Don't think a fuel Leaque as I...
Dan,
I had a similar problem you have a leak or crack in the fuel filter housing mine was a leak in the heat sensor pug on the housing its self. This causes the engine to lose prime..pumb the primber bulb as much as you can and you will see a slight leak..it cost me around 400 to get it fixed but you can do it yourself in about an hour pretty easy fix.
Sep 12, 2010 | Jeep Liberty Cars & Trucks
98audi a4 Q 2.8 cracked oil filter housing?or cooler?same thing?
hi did you get a solution for this? the same thing happened to me too.I had my oil change yesterday and today I saw the engine oil pressure lights come off and the oil started leaking very bad and the mechanic told me that the oil filter housing cracked.
Mar 11, 2010 | 1998 Audi A4
I need to replace the oil pressure switch in a 98 Plymouth breeze. Can you help me?
yes its easy to locate because its green in colour its located on the back side of the engine under the air filter casing and the exhaust manifold its best got at from under the car hope that helps
Nov 19, 2009 | 1998 Plymouth Breeze
Convergence
convegence amp ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
93 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
