Question about Yamaha Audio Players & Recorders
Yamaha rx-v640 shut off
SHUT OFF IN THE MIDDLE OF WATCHING TV. CAN'T GET IT TO TURN BACK ON.
SOURCE: Rx-v800 shuts off after few seconds
Hi, You should try to see, on main board, the ground G2(TP00385), just to make sure if the screw is too tight. Its location on Schematic Diagram (Main) is E8. All the best, Rasgador
Posted on Sep 17, 2007
  • 12 Answers
SOURCE: Rx-V2400 Shut Down
Hi Seems like you have a shorted output channel, remove all your speaker connections and try again, if the problem persist, good chances are that you need to replace a couple of power transistors, let me know if you need more help, I've fixed some Yamaha amplifiers with this problem Good Luck Miguel
Posted on Oct 06, 2007
  • 236 Answers
SOURCE: yamaha receiver model rx-v550
it is your protection circuit working, preventing the unit from any further damage to circuitry. you can check first your speaker cabling for any short connections, possibly red/black terminal wires got entangled. if all ok then try removing all speakers then turn on the amp. if still does the same thing turning off then you have a problem with the amp output stage, shorted power output transistrs/driver probably. if the unit turns on normal without the speakers then you must have one or both of your speakers busted. by the way this amp is multi channel, after removing ALL the speakers connected, and does not turn off anymore, put the speakers back one by one and observe if the unit with turn off and on which set of speakers. otherwise if still trips even without the speakers, it is your amplifier that is deffeective, any of the five channels, main, rear,center. let me know result so i can guide you on how you can get it repaired and what will be the extent of damage in case.
reden
Posted on May 22, 2008
petraman7
  • 1175 Answers
SOURCE: yamaha rx-v461 not working
Does the reciever have separate speaker switches?
Try turning off the speakers and turning on the amp.
If it doesnt have speaker switches , make sure ALL the speakers are connected at both ends and try turning on the amp again.
Posted on Feb 04, 2009
SOURCE: Yamaha RX-V2400
Had same problem. Display would read, "Check Speaker Wires". Rear speakers were shorted by a carpet nail. Works fine now.
Posted on Dec 28, 2009
My receiver just shut off while watching a movie and won't turn back on. I checked the only fuse i could find. Where to go from here.
Press and hold the "straight" and "Tone control" buttons and press power. This should release the protect lock that the receiver is in. If it shuts back off immediately, then you most likely have a blown amp that will need to be repaired.
Apr 16, 2015 | Yamaha RX-V373 5.1 Channel AV Receiver
Yamaha Receiver won't turn on after USB plugin in. Help!
Unit is in protect mode. Sometimes an ipod draws too much current through the usb jack and causes the unit to shut down due to an abnormal voltage being detectected. Press and hold the 'info' and 'tone control' buttons and push power. This should turn the unit on. Turn it back off and turn it on again and should power up normally. If the ipod continues to make the unit shut down when plugged in, try and make sure it is fully charged before plugging it into the receiver - this may help.
Apr 13, 2014 | Yamaha RX-V375
Yamaha RX-V3300 Receiver shuts off on it's own.
A capacitor problem or overheat problem.
Feb 06, 2014 | Yamaha RX-V3300 Receiver
Have a Sony 32" Bravia TV & Yamaha RX-V5000 Receiver. Unable to get the sound to come from the Stereo speakers connected to the RX-V5000 if watching TV. However, can get the Radio to play through the TV...
You probably want to connect the av Audio output from your tv and connect to the RX-V5000. The audio that you are getting from Radio through the tv is probably coming from the output of the RX-V5000 coming to your tv, to which the desiredd route is the other way.
The Outputs at the back should be labeled to tell you which channels are inputs or outputs.
Oct 09, 2013 | Yamaha Audio Players & Recorders
Yamaha sound bar YAS101BL periodically shuts off by itself
It has an auto sleep function. if no button is pressed after 12 hours it will automatically shut down. See http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/ats-1010/7727/6890
Mar 01, 2013 | Yamaha YAS101BL
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Sound no picture, picture;no sound
a panasonic tv will shut down after a short time with no video input. it sounds like the setup menu in the receiver has defaulted and needs to be setup again to coordinate the audio and video signals. ive seen many yamaha menus default. dont let geeks in your house.
Nov 03, 2009 | Yamaha RX-V663 Receiver
My RX V640 is 5 years old..no problems...no changes to the configuration. when I use to the DTV/Cable setting HDTV..video feed...stereo sound etc is fine. Lately when I try the DVD setting to record TV to...
theb best way to do this is to connect the DVR to the vhs unit and the vhs unit to the tv using red white and yellow for both connections. usually composite video 1,2,3 or 4. DO NOT involve the AVR at all, as it will cause your video and audio to be out of sync.The video will not be as sharp, until you play it threw an up-converting dvd or AVR.
Aug 19, 2009 | Yamaha RX-V640 6.1 Channels Receiver
Yamaha RX-V995 5.1 problem playing DVD's loudly
try using the analog mine had a problem with the dac. have any questions email me at facukoff@hotmail.com
Aug 13, 2007 | Yamaha RX-V995 Receiver
Oct 27, 2006 | Yamaha RX-V800 Receiver
29 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
