Question about AEG Lavamat W1450 Front Load Washer
Can I use hot water supply only on my AEG Lavamat W 1159?
Can I use hot water supply only on my AEG Lavamat W 1159 Electronic? This is because the cold water supply line is leaking, and surely its cheaper to start with hot water than heat it in the washer?
  • 135 Answers
A valid point but unfortunately your machine is programmed to take both and will register this as a fault.
This is probably not what you wanted to hear but please dont shoot the messenger.
Posted on Jan 23, 2009
My AEG lavamat 541 washing machine is not draining
Select the program of draining or spinning.
You should hear the drain working. If not, don't insist.
Turn it off and pull the power cord out. After that, you should clean the filter of the appliance. This is located on the bottom of the front panel. Just watch out ..becuase when you unscrew the filter, all water will come out from there. Be sure you have a towel beside you!
After the water comes out, check into the hole of filter if there is any object that blocks the pump to work. If you find something, perhaps you solved the problem! Here is the user instructions of how you can do it. AEG Lavamat 541 electronic Operating Instructions Manual
Mar 01, 2017 | AEG Washing Machines
Where is the filter for die AEG lavamat 538 washing machine and how do you clean it?
The only filter/screen I am familiar with is the one in the hoses the supply hot and cold water to your machine. They should be checked once in a while but I have never found much in them.
However, the manual for your machine is located here:
AEG OKO LAVAMAT 538 Operating Instructions Manual
Best wishes,
Joe
Aug 24, 2016 | AEG Washing Machines
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 88830 Update Gives me the code C7. Whats wrong?
C7 error is th\at no heating of the water has happened. check the heater (most likeley) also can be faulty relay on electronic. ntc fault, pressure switch or wiring to any of them.
Nov 09, 2010 | AEG Lavamat 88840 Front Load Washer
Alarm on aeg lavamat washing machine is E20. What is this?
saup box prop,, clean vith hot water in 2 min have fromt pump open and fluss aut
Dec 13, 2009 | AEG Lavamat 72640 Front Load Washer
AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Aug 22, 2008 | AEG Lavamat 72640 Front Load Washer
Washine machines
Yes. There is a part that allows you to connect the cold water supply to both the hot and cold inlet hoses. It has worked successfully on our 6100 for 8 years or so. I think it was part of the original kit rather than a subsequent purchase - it's a Y-shaped yoke with an inlet connection and two outlets that accept the two hoses feeding the inlets of the machine. From memory i tink the situation is mentioned in the user manual somewhere.
Jun 10, 2008 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat W1450 Front Load Washer Logo
208 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
