Question about Sony Playstation 3 (PS3) Console
Ps3 not connecting to TV
My ps3 is not connecting to any of my televisions. i made sure that the rca cord was plugged in right and even tried using a different one and still i got nothing. help?
  • pj92192 Jan 22, 2009
    what one? the one on the ps3 or the controller?
Keep pressing the power on button until you hear a "bip", that should reset your ps3 configurations and then it apears on your tv screen.
Posted on Jan 22, 2009
  • vokal1992 Jan 22, 2009
    on the ps3.
    it worked?
How to connect to tv
There are several ways to connect a game console to a TV. The question is, what system are you trying to connect? Some features may be available for the newer generations, that are not on older models. I'm assuming, since you have posted with a picture of a Sony Playstation 3, (PS3) that is the system you are trying to connect. The easiest way to install is to use the supplied (RCA) connection cords that comes with every PS3 system. One side connects to the corresponding port in the back of the system, and the other end has (3) multicolor plugs. They will match the colors on most TV's. Some of the older TV's do not have the RCA ports and will require an adapter to connect this way. These colors are; YELLOW (video out) RED (audio out right channel) and WHITE (audio out left channel or MONO) The PS3 also has and HDMI port, and is much simpler to connect the TV and game console together. As I stated before, not all TV's are equipped with HDMI. HDMI cables carry both the video and the sound through 1 cable. To install this way, simply turn on your TV to the correct aux port, in this case HDMI, then connect the the HDMI cable from the PS3 to an available port on the TV. After you have connected the cords, turn the system on and it will tell you that it has "Detected an HDMI connection. Would you like to use this connection?" Select yes. The rest is automatic.
Also, if you didn't know and are needing a new rca cord to connect to the TV, search for a cord from one of the older systems in the SONY family and they will save you some cash, as they are all exactly the same. PS1, PS2, and PS3 all use the same connection. I hope this helps. Good luck!
Aug 25, 2015 | Video Game Consoles & Games
I have my ps3 plugged in but powered off so just a red light is on.i push power button light turns green I hear fan come on and everything sounds normal but it has no picture at takes cd no pro
Rudy, are you connecting to the TV with HDMI, or RCA cords? HDMI carries both picture and sound thru 1 cord, whereas RCA splits it to YELLOW RED and WHITE. The HDMI connection is automatically detected when connected to your TV. It will say"HDMI is detected, do you want to use these settings?" RCA is not automatic, and is prone for the video(YELLOW) cord to develope a bad connection. I wouls duggest first replacing the cord. They are inexpencive, and the fastest way to check your issue. I am going to include a link to a youtube video that will guide you through the steps on how to reset your video settings on your system.
How To Reset PS3 Video Settings PS3
Oct 08, 2014 | Sony Playstation 3 (PS3) Console
How to connect to PS3
if your tv has an hdmi conn, use that, if not, use a standard playstation to rca cord
Jan 25, 2013 | RCA HD61LPW42 61" Rear Projection HDTV
Toshiba 20WLT not working with PS3
The PS3 has to be configured to put out HDMI or AV(RCA plug)output.The easiest way to switch between is to connect both cords to the same TV,so you can swap to the other ouput and verify it works.(In other words,if you had the PS3 set on HDMI,you have to connect with an HDMI cord unless you change it in the PS3's settings).I think this was an energy saving solution by Sony,bacause I'm sure they could figure out how to make both work at the same.
Mar 13, 2012 | Toshiba Televison & Video
I recently moved house and have connected my ps3 80gb to a TV not previously used to connect the ps3 to. When I switch on the ps3 all I get apart from the Sony log on tune is multi coloured vertical wavy...
It sounds like the PS3 is sending a signal that the television isn't 100% compatible with. I'd start by plugging the PS3 in using standard RCA jacks, and making sure that the video and audio configuration settings are all set to automatic. Then, plug back in using the HD cords that you have, and the PS3 should reconfigure its signal output to match what the TV can handle.
Mar 16, 2011 | Video Game Consoles & Games
How do I get the input to work for the PS3 on a a RCA truflat tv, the cords are connected properly, we tried all the inputs. now what?
If the PS3 was hooked up to another TV, perhaps with the HDMI, the PS3 needs to be reset. With the PS3 off, press and hold the Power button for approx. 10-15 seconds until it beeps again. This should provide picture/sound through the A/V cable. Hope this helps.
Jan 12, 2011 | RCA TruFlat 27F520T 27" TV
Iam not able to get a picture from my hdmi cable, but can still here sound. tried three different hdmi cables... please can you help...
1. Your Connections Are Faulty
Quite often, the cause of the no picture problem is a simple one - loose cords. Make sure that the cords are plugged in tightly, both on the TV side and the PS3 side. This is especially true with the HDMI cable connection on the PS3. Often, it looks tight, but you still might need to wiggle it a bit more to seat it correctly. Along the same lines, make sure that the cords you are using are new and match the connections properly on both the TV and your console.
2. Wrong Connection Settings
If you are using the HDMI/DVI cables and you don't get any picture, make sure to check your video ouput settings. If your PS3 thinks you are using standard A/V cords to connect to the set, you'll have issues. The opposite is true too - if you are using the A/V cords and your PS3 thinks otherwise, you'll have the same no picture problem. Make sure you settings match the types of cable connectors you are using.
3. Wrong Resolution Setting
This is also an easy mistake to make that can result in no picture showing on your television screen. For example, if you've been using your PS3 with an HDTV and then try to hook it up to a standard definition television set, you'll encounter this issue. The cure is simple; just go into your settings and switch back to standard resolution and then restart your system. The 720p resolution is the default setting and this should work for most standard definition televisions.
Nov 18, 2010 | Sony Playstation 3 (PS3) Console
Need Help
try connecting A/V rca cable first. go to ur diplay settings and then to video output settings in it select av multi. don't use HDMI settings let it automatically ask u when u plug in hdmi cable. Then switch to HDMI cable. I had a problem like this before with a ps3 that i had bought used. hdmi was set up and it took forever to set it up with rca cords. took many times power on and offs and unplugging video cords for it to reset. . not sure. Now when u plug in your hdmi on any tv it should automatically set up. and you have settings for a/v as backup. the other thing is it could be the just the port or cable.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Ps3 hdmi cable with adapterto tv's rca's
Just use the regular AV cords. They are 480i using an HDMI to this and that isn't going to improve picture quality.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
No power on PS3
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
