Question about Kenmore Elite 45986 Front Load Washer
Moving How do I put the bolts back in the barrel for transport?
  • 640 Answers
Just go to the back of unit and place the bolts with plastic,,and or rubber grommet back in the hole and tighten,,,if you cant see the hole remove the for plastic cap..theres 4 white caps,,,onthejob
Posted on Jan 23, 2009
Install shipping bolts
This will not be necessary if the machine is transported on its back lay it down carefully on its back should not be a problem
Nov 06, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Do bottom two bolts in rear of machine have to removed before operating?
if they are transit bolts they do is it a new machine or has it just been transported if you cannot move the drum from side to side take them out only used for transporting
Dec 01, 2011 | Whirlpool WFC7500VW Washer
I have an american standard tub and it constantly clogs. I used drane-o and it worked for a little bit but I think its the drain in the tub. How Can I tell if thats the problem?
Take screws out of plate on tub over flow and pull up trip lever. sometimes they move and need adjusting . It shoul dhave 2 bolts holding the plate on tub at overflow and work with it to remove trip lever assembly once out run some water down drain to let you know if that is th eproblem then you can adjust on trip lever assembly by moving the little barrel like plug near the handle a little will increase water flow out of tub once you put it back in you can adjust it out it back in with out bolting back turn water on and move lever to see if it drains any better.
They can be tricky but you can do it.
Mar 21, 2010 | American Standard 1583.470.020 Universal...
I am looking to buy a used 4 year whirlpool duet washer and dryer. Do you need transport bolts to move either? Also what capacity is the washer and dryer
The transport bolts are required to be installed before transporting the machines. This is to support the suspension system to prevent damage to the machines during transportation.
The washer has a capacity of 9.0 kg or 19.8 lbs with a volume of 3.7 cubic feet. The dryer's capacity is 7.0 cubic feet.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you change a key barrell on a 1997 vw transporter van
if it is dooor lock you have remove door trim , and insert key in hole and find some pressing notch is there on back side of lock , turn the key and keep pressing that notch and pullout barrell, it will come out , in same way you can fix new barrell.
Jan 21, 2010 | 1997 Volkswagen Eurovan
I have a LG WM0532HW. What are the drum bolt sizes thr.& length
Hello Jeff,
Unfortunately, these are specially made bolts that have threads only on the first section of the bolt, so they can secure the wash drum and not interfere with anything else. You also need the special sleeves for the bolts. I would not try to use standard bolts from a hardware store, as they could damage the wash drum if you overtightened them or they were too long. LG, and most washer manufacturers, don't publish the size, thread count and length of their transport (shipping) bolts, hence the reason they advise to keep them for future use.
So if you're only moving the washer down a set of stairs, you should be fine if you take it easy and either hand carry it with two (2) people, or use an appliance truck to move it down the stairs.
If, however, you're looking to move the washer any distance via truck, etc., you'll want the shipping transport bolts and sleeves to keep the drum and suspension system from getting damaged.
You're best bet is to get in touch with LG customer support and obtain a set of the transport bolts. You can reach them by callling them from 8AM to 8 PM toll free at 1-877 714-7486 and follow the prompts to reach customer support.
Here's a link to the owner's manual for your washer, just in case you've misplaced yours.
http://aic.lgservice.com/gcsc/dwn/main
Hope you find this Very Helpful and best regards!
Dec 13, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Broken release on rear passenger seat
No, you would have to remove the seat completely any way.
Move seat all the way back, remove bolts
Move seat all the way forward, remove bolts
Tilt the seat forward to unplug any connectors
Sep 05, 2009 | 1999 Volkswagen Passat
Lock barrell on the drivers side is broken
you'll need to remove your door panel (screws are by the door handle, arm rest, under door and side of door) and pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything.
I'm not sure what you mean by lock barrell.. I'm guessing the cylinder which you'll just have to bolt back onto the door.. you may need to find a specific bolt though....
Aug 10, 2009 | 1998 Volkswagen Passat
URGENT~no clue how to reinstall transport bolts for moving washer
The long one go on the bottom and the short one go on top the hole for the shipping bolts are on the back might have a clear plastic cover over the holes on the back panel there is only one way to put them in start by hand tighten the bolts with nothing in the drum the holes should line up one you fill the catch and get hard to turn start using a wrench when it is done try shaking the inner tub it should not move all the shipping bolts do is keep the tub from slapping around inside the cabinet and breaking things Good luck
Apr 03, 2009 | Washing Machines
Installing transport bolts
yes there is you best to remove the 3 screws holding the top on slide back remove then you can move the drum around usley have someone pull up install bolt
Feb 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
102 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
