Question about NEC NP500WS LCD Projector
Fuzzy images, MacBook Pro to NP500WS projector
Can't figure out why image from my 2011 MacBook Pro is very fuzzy and quite blownout on my NP500WS. Tried all kinds of color profiles, resolutions settings, to no avail. I don't use it often, last time was a couple of years ago and it looked great. Same behavior from an older black MacBook to same projector. Tried 2 different DVI cables, same fuzzy appearance. Any helps or tips, folks? Thank you.
  • John McClung Jan 14, 2013
    Buried in the user manual is info that for DVI, both laptop and projector should be off, hook up the DVI cable, then start the projector, finally boot up the laptop. Wish me luck, I'll report back.
    Habit-Forming:
  • 81 Answers
Are you yielding the same results using a different laptop?
Posted on Jul 20, 2017
SOURCE: Ghosting
Get firmware upgraded.
Posted on Feb 07, 2008
  • 4234 Answers
SOURCE: new lamp but image is dim
This usually means that there is some contamination in the light path. Since many of the mirrors and lenses must be carefully aligned, it is not recommended to have the homeowner dis-assemble +/or clean these. This unit should be sent in for serive, requesting a complete clean and alighment. The unit will be cleaned, any filters changed and the convergence checked.
Dan
Posted on Feb 02, 2009
vortash
  • 431 Answers
SOURCE: Pink cast in images from NEC VT540/440 projector
Sounds like one of those problems only cureable with expert knowledge of for example Chroma feed , Lcd function , lamp luminence, not to be a killjoy but it sounds like this is one for the engineers an estimate should be free and even if you dont have it fixed you'll know whats wrong if you want to do it yourself providing you have adequate training of course .... Regards vortash
Posted on May 10, 2009
projdoc
  • 2237 Answers
SOURCE: nec projector
go into menu, under image, and chose ceiling.
Posted on Aug 04, 2009
projdoc
  • 2237 Answers
SOURCE: Image upside doen on philips data projector
go into the menu under settings and change the image from ceiling to front.
Posted on Jan 06, 2010
Dim, dark, fuzzy
your light tunnel is out of adjustment or has collasped.
May 16, 2010 | InFocus IN26 Multimedia Projector
Fuzzy scanned image from Epson Expression 10000XL scanner
Make sure that the item being scanned is lying flat against the scanner's glass. If the scanned image is still fuzzy after adjusting the object, clean the scanner glass with a lint-free cloth and some vinegar or ammonia-free window cleaner.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Apr 10, 2010 | Epson Scanner Expression 10000xl Pro A3+...
Pc to projector fuzzy as hell, all diff resos.
Well the ax-100 can only display 1280x720. If you output anything different - lower or higher - the image needs to be rescaled, which inevitably makes it a bit fuzzy.
May 29, 2009 | Panasonic PT-AX100U-EC DLP Projector
Fuzzy image quality
This has nothing to do with your cam. Its a result of bandwidth and transmit speed. Nothing you can do except get a faster connection.
Feb 28, 2009 | Logitech QuickCam Pro 9000 Web Cam
Fuzzy image
if you are in a poorly lit room, the picture becomes fuzzy, or you need to reinstall your graphics driver to give a better image clarity
Aug 17, 2008 | Creative Labs WebCam Live!
ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
May 12, 2008 | Elmo Projectors EV-2000AF Multimedia...
Unclear, fuzzy image
Hi there
Try another S-Video cable , if the problem still occurs you will have to replace the Mainboard
Nov 07, 2007 | BenQ PB6110 Multimedia Projector
NEC NP500WS LCD Projector Logo
52 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
