Question about ASUS P4S533-MX Motherboard
I am trying to install a faster CPU 1.7 to 2.8 GHz.
What do I need to to do? I know this board has jumpers or can be changed n the BIOS. I don't know what to set the jumpers or BIOS to.
Thanks,
jp
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    I take it the board still boots with the 1.7 in place? Not with the
    2.8? Did you default by moving the jumper from norm to clear cmos and
    back, and try again?
  • Bruce Volkers
    I take it the board still boots with the 1.7 in place? Not with the 2.8? Did you default be moving the jumper from norm to clear cmos and back, and try again?
  • 64 Answers
You can find all the answers you need by downloading the manual for your asus MB from this address.
http://support.asus.com/download/download_item.aspx?model=P4S533-MX&product=1&type=All&SLanguage=en
Posted on Jan 24, 2009
Installed athlon 64 x2 5200+ in dell demension c521 and got a black screen! What's The Problem???
Well, I see two issues that this could possibly be the most likely is that your computer will not support the 5200 chip. The second is that the Video card has come unplugged. All the Documentation indicates the board uses a 3200 and there is no section for upgrading to a faster chip. The link below is a link to the Manual on your computer in pdf format.
http://support.dell.com/support/edocs/systems/dimc521/en/OM_EN/RP333A00.pdf
Make sure the video card is properly installed and attempt to get into the BIOS to see if the CPU is recognized. If the BIOS fails to identify the CPU you are using it is not compatible with the motherboard and you will have to replace it. If you have any diagnostic lights activated then look up the sequence on page 48 of the manual I provided a link to. Only Dell Support could tell you if there is a jumper you can change to make this newer CPU work but I doubt that CPU is going to work in that computer. Name brand system are hard to upgrade because of this weakness.
Aug 14, 2011 | AMD Athlon 64 X2 5200+, 2.6 GHz
Hi! I just made a cpu swap on my asrock p4 combo from socket 478 - 775, the new cpu is the 570J 3.8 ghz 800 mhz fsp 1 mb chache ofcourse i looked at the manual and changed the jumper settings from...
According to the Asrock site, the CPU you chose should work in your board. You are going to have to check the jumper settings, (see the manual page 11) jumpers J1,J2,J3,J4,J5,J6,J8,J9,J10,J11,J12,J13,J18,J21 only. You indicated that you also changed J7,J14,J15,J16,J17,J19,and J20 since your statement was "i looked at the manual and changed the jumper settings from J1-J21"
Also make sure you do not have a jumper block on the CLR CMOS down near the battery. If you left a jumper on, it will not boot
Also, make sure you installed the CPU correctly and did not accidentally bend a pin on the underside. see 2.2 on page 12 Installing the 775.
Dec 23, 2010 | Asrock P4 COMBO...
Can I install a better CPU into my Toshiba Satellite P305D-S8834 17 1 Widescreen Notebook Computer then the AMD Turion X2 Processor RM-70 it came with?
Changing CPU is a serious change. When your unit was built the processor speed and type were written into the BIOS. When we change the CPU to a different type there is a chance that the BIOS will not recognize it and refuse to boot up. Also Windows was installed with the original CPU and a major change in hardware could mess up Windows.
I did some research and found this model comes with a 2.0-GHz AMD Turion X2 Dual-Core RM-70 CPU and 4GB of RAM. This is not the fastest CPU that can be put in a laptop but a very good one. (faster than mine)
I can guide you through the steps to replace it but my advice is stick with what you have until it breaks and buy a faster laptop. The upgrade won't gain you enough to justify the expense.
May 21, 2010 | Toshiba Satellite P305D-S8834 Notebook
I added a Pentium P4 2.66Ghz cpu 533FSB, Bios appears and says the due to new cpu installed system has started at 64Mhz please select correct Frequency. I select 2667 Ghz and 133Mhz saved and restarted....
Turn the computer off.
Turn the computer on.
Wait a minute or two -- it may "time-out" and reset it to the "slowest" speed.
If that fails, look closely at the motherboard,
or read the manual for the motherboard, to find a "clear BIOS" jumper.
Turn the computer off. Move the jumper from "1-2" to "2-3".
Wait a few seconds. Move the jumper back to "1-2".
Turn the computer on, with the "default" settings.
Oct 28, 2009 | ASUS P4S533-MX Motherboard
I put my 3 0 ghz cpu in my Gateway Intel 850 Socket 478 ATX Motherboard no video from agp is new board with 2x 256 rimm pc 800 pc seems to start all the fans as well new power supply 512 ati vid card but...
Remove the BIOS recovery jumper near the battery on the motherboard and attempt to boot. If the system displays a startup screen, replace the jumper on pins 1 and 2 (pin 1 will have an arrow by it) and configure your bios appropriately.
Mar 16, 2009 | Computers & Internet
I want upgrade
hello, i would install the cpu you wish to use, then see how it runs. and then do a bios update. this may work,if not the motherboard may not be compatible with the cpu upgrade, (propriatory equipment sometimes does not allow such upgrades) like hit or miss! i hope this info helps,and you get the dell to accept the faster cpu. good luck! glen
Feb 15, 2009 | Dell Pentium 3, 500 MHz Pentium III-M...
UNDERCLOCKING
Hi, open your manual to section 1.9, page 1-12. Follow the instructions to clear the cmos. (Do not forget to set the jumper back to normal).
If you no longer have your P4S800D-X manual, you can download it in PDF format from Asus at this link;
http://support.asus.com/download/download.aspx?modelname=P4S800D-X&SLanguage=en-us
Need Adobe Reader? Download here;
http://www.adobe.com/products/reader/
Once the cmos has been reset your CPU should show auto the CPU to its default settings.
Mike
Aug 23, 2008 | ASUS P4S800D-X Motherboard
CPU model not recognized correctly
Any multiplier settings in bios? try using something like CPUID in your OS to see if it clocks faster then what bios tells you?
Feb 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Cpu install
If you go in to the bios you should be able to change the multyplier from x6 to x16.
Failing that try loading optimized default in the bios. :)
Dec 20, 2007 | Intel Motherboard
Foxconn 945G7MD will not start every time switch on
Does the unit start with the board removed from the case? If so I would say you have a grounding issue. Make sure you have the little insulated washers on all the screws holding the M/board in the computer. Other than that try resetting the bios using the onboard jumper, usually jumper J4 or JP4
Nov 18, 2007 | Computers & Internet
ASUS P4S533-MX Motherboard Logo
141 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
