Question about Coleman Retro Rechargeable Battery Powered Lantern Family Size
Circuit diagram coleman 5312
Has anyone a circuit diagram for a coleman retro lantern 5312. Light flicks on but does not stay on battery OK (Charge test OK using a voltmeter.) Thanks Bruno Colangelo (aquila@bold.net.au)
  • David Abramson
    David Abramson Dec 17, 2016
    Did you ever get an answer to this? I have the same problem
3 Suggested Answers
joboo1
  • 257 Answers
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Posted on Mar 16, 2009
al_kupchella
  • 843 Answers
SOURCE: In the Coleman 5312 Retro Series Lamp is it
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
Posted on Dec 03, 2010
Does not switch on after fully charging night light works if charger is plugged into power point
will the main light come on when plugged in? it might just need a new bulb. if so it might be a dead battery
Mar 11, 2014 | Coleman Retro Rechargeable Battery Powered...
Charge Time for 5312 Lantern Battery?
Charge time is 18hrs. If you left it on and it was flat, imediately charge for 40hrs.
heres the manual.
http://r1.coleman.com/Manuals/5312R.pdf
Feb 12, 2014 | Coleman Retro Rechargeable Battery Powered...
Coleman lantern #5312 spiral bulb. problem: night light works ,battery fully charged. turn on hi knob; tube will flash momentarily then goes out, low setting will not come on. turn off and on several...
Most times the problem with these is that the batteries, though they show fully charged, are in poor condition.
Test: Count the cells in this unit and multiply by 1.2 test for that voltage, 4.8 is common, at the batterypack and turn the light on, if the voltage falls below 1 volt per cell, the battery protection circuit will engage and turn the light off. This is a battery problem.
If the voltage stays relatively steady, the bulb is the second item to be a common failure. Shine a flashlight across the base of the bulb where the 2 ends enter the white base. It the tubes are pretty blackened, your bulb is likely bad.
I don't have the specs for that switch, but it's a pretty simple device, it connects power from the batterypack to the inverter board or to the nightlight. It's simple to test with either an ohm meter (power disconnected) Or a volt meter, (Power connected)
Jan 12, 2018 | Coleman Electronics - Others
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
In the Coleman 5312 Retro Series Lamp is it supposed to work off the mains charger even if the battery will not charge. Battery is confirmed dead but lamp will not work on mains nor on 12v car lead. Don't...
Dec 03, 2010 | Coleman Retro Rechargeable Battery Powered...
How do you relamp the GE model 17000 lantern
Visit the Coleman site to locate your particular lantern.
http://tinyurl.com/2a9j2xx
Jul 02, 2010 | Coleman Retro Rechargeable Battery Powered...
Coleman lantern/fan/radio won't take a charge any more.
Yes there is, you can check out http://www.batteryinternational.com/lantern-battery.html to find a replacement, or call 1-877-28-BATTERY if you're having difficulty finding the battery you need. Hope that helps.
Jun 14, 2009 | Coleman Lantern Fan Radio (841.321) AM/FM
Coleman Retro Rechargeable Battery Powered Lantern Family Size Logo
312 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
weirdtop
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
