Question about Kenwood Audio Players & Recorders
I have a kenwood cd/tape xa3 that shows no disc with a disc inserted. Whwat is the problem?
5 Suggested Answers
marked
  • 6487 Answers
SOURCE: stopped playing after I inserted damp CD in 200 disc loading mechanism
Try using a CD cleaner to clean your player ...
Hope that helps....
Posted on Jul 10, 2008
stif_NEC
  • 441 Answers
SOURCE: nothing is openning
Thank you for using FIXYA!
Does all your CDs not working when you insert them on your CDROM drive? There is a possibility that you CRRom drive's lens is failing. You can try cleaning it with a lens cleaner Or try this steps below.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
If this steps did not fix the problem i would suggest buy a new one to save you the hassle and time.
Sincerely,
stif_nec
Posted on May 22, 2010
  • 4 Answers
SOURCE: placing good cd-r disc for recording shows "insert
u mabe inserting the wrong disc all phillips cd recorders uses cd-r or cd-rw that says digital audio.
Posted on Aug 03, 2011
  • 444 Answers
SOURCE: after inserting cd player says no disc
The lazer is shot in it, It is not reading the info on the disc any more.
Posted on Oct 28, 2012
Stopped playing after I inserted damp CD in 200 disc loading mechanism
this can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Jul 04, 2008 | Kenwood DV-5700 Multi-disc DVD Player
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
Placing good cd-r disc for recording shows "insert
Jul 28, 2011 | Philips CDR785 3-Disc CD Recorder
Error 5 keeps showing up when I want to play cd.
Go to your local store and buy a CD laser head cleaning kit. Usually has a single CD that has what looks like brushes attached to it... run that and it should clear up your "can not read disc" error. Also.. pay close attention to the media you are inserting. A lot of CD players can't read CD-RW media.
Mar 24, 2011 | Kenwood Car Audio & Video
Kenwood ddx7017 when i insert cd/dvd it reads mecha error
sound like disc read error. data on disc(cd or dvd) is not finallized, or not complete...or lense/lazer problems....TYPICALLY sound like a product defect!
Jun 23, 2009 | Kenwood Car Audio & Video
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
Transfering my video tapes to DVD
A couple of quick observations: -If you have two or more optical drives you could be inserting the disk in the wrong one. -You may have just misspoke when you said *insert into the DVD/CD burner drive a CD-R disc* but just to make sure you need to be inserting a blank DVD disk and not a blank CD. No offence intended, especially since I?ve made both of these mistakes in the past myself :)
Jan 02, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Remove DISC010 error
If there is a disc in the changer (I guess it's in the tenth slot), try removing it, if it doesn't work by 'normal' means and you feel brave, try shaking the unit a bit. If it doesn't help or you don't feel like banging on it, you'll have to take it for a repair (they open the unit and extract the disc, they get jammed sometimes).
Nov 05, 2005 | Kenwood CD-423M 200-Disc CD Player
23 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
