Question about Samsung HLS5688WX/XAA Rear Projection Television
Samsung HLS5688WX/XAA audio - Samsung HLS5688WX/XAA Rear Projection Television
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: "my samsung lns4051dx xaa powers on and the audio
It can be T-CON board, 24vdc power supply, backlight inverter board, main board.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Oct 23, 2010
My Samsung LNS4041DX/XAA audio is degraded
https://www.cnet.com/forums/discussions/samsung-lns4041dx-xaa-lcd-tv-has-sound-but-no-picture-513963/
Apr 07, 2017 | Samsung Televison & Video
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Samsung hls4676sx/xaa sound cut off and speaker cracks
Sounds like an analog board problem--IIRC this has the audio amp on it.
Mar 05, 2014 | Samsung HLS4676S Television
Funy distortion on hi sound frequuence
I have the same problem I just shut it down wait for the lamp fan to stop and then unplug it for 30 seconds and it fixes it for awhile. Was looking for a permanent answer here.
Feb 22, 2014 | Samsung HLS5688WX/XAA Rear Projection...
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung HLS5688WX/XAA Rear Projection Television Logo
Henry  Thomas
Henry Thomas
