Question about HP OfficeJet Pro k550 Printer
K550 air in ink feedlines
Air in all feedlines
one or more colors not printing at all or light print or one or more colors with streaks. I will run several printhead clean cycles and heads will start to print correctly. I will print several pages of mixed text and graphics and the problem will repeat. printhead health will change to fair on one or both printheads. KY printhead New, MC printhead used,
Ink Levels K 95%, Y 54%, M 76%, C 71%, Genuine HP Ink 88XL cartridges, from Sam's club less than 2 weeks old. Page counts as follows Tray 1 = 144, tray 2 = 699, Auto duplex = 28 total = 871.
Printhead expiration date: KY 11-26-2009, MC 4-23-2010 Ink Expiration: Bkack: 6-4-2011, Y-C-M all 7-2-2011, after several cleaning passes one or both printhead helth may return to good.
  • 1 more comment
  • Carl2020 Jan 23, 2009
    Prblem found. Ink station improperly installed (at factory?) Needles not going fully into ink cartridges so that sometimes they would pickup ink and sometimes air. Thanks for the help
  • Anonymous Apr 06, 2009
    No color prints and the black is very light. I inherited the printer so it wasn't used for 3 months, but have since replaced all cartriges and need to know how to fix.
    Thanks,
    Bruce
  • Martin Smallridge
    Martin Smallridge May 11, 2010
    The K550 is essentially a continuous ink supply (or CIS) system built into a printer and as such it's prone to the same kinds of issues.
    The black is particularly prone to issues with clogging in dry, hot environments because it's a pigment ink (which tends to clog quicker than the other dyebase inks) but your problem doesn't bear the hall marks of that issue.
    It sounds more like there is either an air leak in the system or a problem with the cleaning system. The confusing symptom is that more than one ink is being affected which is unusual.
    Could you be more specific as to which colours are being affected and if possible provide some images/scans of the sort of streaking you're seeing.
I have had this happen a couple of times and have cured it easily. It has only happened with the black with me. It seems to be caused by air in the ink feed line. With the printer switched on open the top cover and hold the resume button for 5 seconds. The printheads should move to the left and you may be able to see air in the pipe(s). Remove the printhead of the offending colour(s) then insert a syringe with the plunger fully down into the rubber that the printhead connects to. Draw up the syringe plunger to draw ink/air through until you can see no more air in the pipe. Replace the printhead and close the cover. The printer should now do a calibration with the offending colour hopefully now working.
Posted on Mar 29, 2009
  • HP Master
  • 419 Answers
Not sure what to do in a situation like this but I'll post this as a solution as we seem to have found it even if I didn't actually realise it was... Who knew :)
Posted on Jan 23, 2009
Streaks on color only
your printer has two ink cartriges one with black ink and the other for color when they get ready to run out they will leave streaks
Dec 07, 2012 | Office Equipment & Supplies
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
Ink cartridge installed but cartridge light continues to blink
Have you only replaced the magenta cartridge, or have you also tried the print head. A bad print head can cause the ink to read as empty or clogged.
Mar 15, 2010 | HP OfficeJet Pro k550 Printer
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be dry.so it cant able to print
Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Yellow Light on HP K550 indicating open panel will not turn off.
If the printer is connected to your computer - check to see if there is a blinking Red exclamation point / printer icon in the system tray. Sometimes mousing over this icon to see the tooltip is the only way to figure out what error message the printer is trying to tell you.
For us - when this happens, the printer is complaining about an "incompatible" ink cartridge - even though 99% of the time it will print from that cartridge without problems. So try removing and re-inserting all of your ink cartridges too.
Sep 30, 2008 | HP OfficeJet Pro k550 Printer
Canon Pixma 600 printer showoing a green streak
You may running out of the colored ink.. just make sure you change it before it runs out.. make sure you buy a colored ink for Canon Pixma iP1600.. the cartridge of the colored ink of your printer has a number infront of it.. eg: Canon CI-41
Sep 21, 2008 | Canon PIXMA iP1600 Printer
DeskJet 9800 Streaks in Color Print
That is the problem, you need to expost the track wheels and clean them with a paper towel soaked in rubbing alcohol.
Jun 27, 2008 | HP DeskJet 9800 InkJet Printer
HP K550 blak print failure
Hold the far button on the right down for a minute and it will move the head over for access
Jan 06, 2008 | HP OfficeJet Pro k550 Printer
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
HP OfficeJet Pro k550 Printer Logo
860 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
