Question about Kidde Nighthawk Combo Gas/co Detector
What does a readout of "L6" mean?
It also chirps once every 30 seconds. It plugs in or takes a 9-volt. Thanks
  • Joebb Feb 14, 2009
    I unplugged the unit for a few minutes, then plugged it back in. Now it's giving me Lb and beeping every 30 seconds no matter what I do. The battery is at full charge.
L6 is Lb = Low battery
Posted on Feb 05, 2009
What does L6 mean on my Garrison carbon monoxide detector, it beeps then that message flashes, and then it beeps again . It is a plug in and does not need a battery.
L6" display & chirping sound, indicates you need to change the 9 volt battery in the detector.
Please rate me as HELPFUL.
Jan 26, 2017 | Home Security
My hard wired smoke alarm has had a new 9 volt battery installed and even a second new one installed and is still chirping 4 times every 30 seconds.
On many of the newer smoke alarm installations, all of the units are wired together so that if one goes off, it triggers all of the others so that no matter where you are you will definitely hear the maddening noise of the alarms! And if one of the other units has a bad or weak battery not only will it chirp but so will the others.
Only way around this is to cut any and all wires going to each smoke detector. They will still work because each has its own battery but there will be no more triggering of other units.
Oct 27, 2016 | Cars & Trucks
My CO alarm is beeping and the LED display says L6. What does that mean and what do I do?
If the alarm chirps every 60 seconds and the red LED flashes with "Lb" this indicates Low Battery.....replace battery as soon as possible!
Nov 04, 2014 | Kidde KNCOBB Basic Carbon Monoxide Alarm...
Smoke detector keeps chirping after battery is changed, chirps every 30 seconds. chirps come from the ceiling not the device
The chirp means the battery you chose wasn't good enough... it has to be the newest '''alkaline''' you can get hold of. If it isn't alkaline that's why you are having trouble. Upon replacement press the button to do a hard reset.
Aug 11, 2013 | Kidde Home
My Kidde Carbon monoxide beeps every 30 seconds and is showing L6 with a flash of 0? It is brand new. What does this mean?
L6 is actually "Lb", which is a low battery warning. If the 9V battery is missing, or if the battery's power is low, an "Lb" message will display, which blink's alternately with the current CO reading, while chirping. If this happens, you need to replace the battery.
Nov 10, 2012 | Kidde Nighthawk Combo Gas/co Detector
My kidde carbon alarm chirp every 30 seconds and shows L6 on the dispaly, also the red light goes off and on
"L6" display & chirping sound, indicates you need to change the 9 volt battery in the detector.
If you have misplaced your User Guide, I have included a link to it, that you can download and print for future reference.
http://www.kidde.com/utcfs/ws-384/Assets/900-0113.pdf
Hope this helps you solve your alarming situation. :)
Mar 02, 2011 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
My casio exilims battery charger light is flashing, i know theres a trick using a 9 volt battery. how can i do it?
you take a 9 volt battery and take a metal paper clip or anything this and metal and connect it from the + side of the 9 volt battery and the - side of the camera batery. take another mateal object and connect it from the - 9 volt battery to the + of the camera battery. hold it for about 30 seconds (it might be easier if someone helps you) and place the camera battery back in the charger. that should give the camera battery enough power to help it boost up its charge and make the flashing stop
Dec 10, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Conair digital answering system
TAD2012 Quick Reference Guide
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit will shut down until the power is restored. One 9-volt battery must be installed to retain your personal greeting message and incoming messages during the power failure. Occasionally outside factors, such as power surges, may adversely affect the unit. If the unit is not operating properly or if the light continues to flash once power is restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Conairphone™ Consumer Hotline
Questions? Call the Conairphone™ Consumer Hotline, toll-free, 1-800-366-0937.
Hotline Hours: Monday-Friday 8:30 a.m. - 9:00 p.m. (EST)
Saturday 8:30 a.m. - 12:30 p.m. (EST)
7475 North Glen Harbor Blvd.
Glendale, AZ 85307
Nov 08, 2007 | Conair TAD 2014 Answering Machine
Kidde Nighthawk Combo Gas/co Detector Logo
2,457 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
