Question about Compaq Presario 1681 PC Notebook
Where is the hard drive on presario 1681
I bought a used compaq presario 1681 and I can not find where is the hard drive on presario 1681
  • Compaq Master
  • 32,281 Answers
Most model Compaq have the hard drive mounted behind a plactic panel on the RH edge or LH edge of the laptop. There is a screw that locks the panel in place. After you remove this screw then slide the panel down to unlock it and then pull the hard drive out.
Posted on Jan 23, 2009
My old hard drive on my COMPAQ PRESARIO C306US died, after I replaced the drive I tried reloading windows XP and I get an error that the hard drive could not be found. I loaded Ubuntu and it recognized the...
check the HD if its properly inserted,if the old one is working before then the new one you bought my be a damage one. try to replace another HD to see if which HD is working or not.
Jun 06, 2011 | HP Compaq Presario C306US Notebook
How do i remove my compaq presario 2200's hard drive?
The Compaq Presario line is one of the longest-running series of computers, originating in 1993 and remaining in production even after the purchase of Compaq by HP. Because of this, many Compaq Presario desktops have required that some of their parts be upgraded or replaced because of the wear that they have received over years of standard use. One of the more commonly replaced Presario desktop components is the hard drives, especially given how much hard drivemag-glass_10x10.gif storage capacity has increased since the Compaq Presario line was introduced. Replacing a hard drive in a Compaq Presario desktop isn't difficult, and can usually be done in a matter of minutes even for users who aren't familiar with computer upgrades.
structions
  1. Step 1Remove the screws holding the left side panel of the computer on, then slide the panel back to remove it. Set both the panel and the screws aside so that you can put the panel back in place once the hard drive has been replaced.
  2. Step 2Unplug the ATA (wide, flat and usually gray) or SATA (thicker, thin and red) data cable and the power cable from the back of the hard drive that is currently in the Compaq Presario. Move the cables so that they will be out of the way, but make sure that they will still be easily accessible to you so that you can plug them into the new hard drive.
Aug 08, 2010 | HP Compaq Presario 2200 Notebook
Replacing hard drive, just want to know if a WD400...
If you want to replace your hard drive, use WD3200BEVE. Its a 320GIG hard drive and it works perfectly. I installed one in my compaq presario v2403nr.
May 20, 2010 | HP Compaq Presario V2000 Notebook
The compaq presario v3000 replace hard drive
Yes of course you can install the Seagate Mementus 160GB, the laptop will take a dive with a 320GB capacity.
Regards.
Dec 02, 2009 | Compaq Presario Notebook
Upgrading Hard drive of Compaq Presario v3018TU
I am afraid you cannot use 250gb hard drive on the notebook. Check the following service manual for hard drive specifications and supported hard drives with part numbers:
http://h10032.www1.hp.com/ctg/Manual/c01035667.pdf
Nov 02, 2008 | Compaq 10.2 GB ATA-100 Hard Drive
Swapping a hard drive
 You should be able to use that Hard Drive in the Compaq. Once transferred, you might be have to download the drivers to make sure all your devices work. I would recomend that you format the drive and reinstall windows.
Nov 01, 2008 | Compaq Presario 5000 PC Desktop
Installing a second hard drive in a compaq presario 70000t
laptop dont use two hard drive if you want to use second hard drive you make it an external
Jun 03, 2008 | Compaq Presario 700 470024-192 Notebook
Can't launch messenger
Do you have internet conected and does it work properly?
Oct 20, 2007 | Compaq 100GB Laptop for Presario 900 &...
Put your windows installation cd in the drive, then reboot. Press any key to boot from cd. Then select R to enter recovery console. Follow the prompts. Once in the recovery console, you should have a C:\ prompt. When there type "fixmbr" without the quotes. Once that finishes type "fixboot" and then let that finish, you'll probably have to type a "y" for yes stating that you want to do these options. Then finally type "chkdsk". This should solve your problem, if not let me know, you'll probably need to do a repair install.
Aug 28, 2007 | Compaq Presario 1681 PC Notebook
Compaq Presario 1681 PC Notebook Logo
151 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
