Question about Plantronics K100 Bluetooth Headset
How do I open the K100, the charger connection has been pushed inside.
Still wondering how to connect Plantronics K100 Bluetooth to my Galaxy S5 phone as a hands free in my car
Here is the user guide. Check out Page 3
http://www.plantronics.com/uk/media/media-resources/literature/user_guides/k100_ug_en.pdf
Sep 06, 2016 | Plantronics K100 Car Hands Kit
Repairing Charging cord on Braun shaver cord
no--simply because there are live wire connections to the transformer that people will touch and then seek compensation for that carelessness
best if you junk it and simply buy a new charger
Jul 10, 2016 | Braun Syncro 7526 Electric Shaver
How do I fix a pushed in charger port on a pink kids Prontotec Wimo tablet?
unless you know how to open the case I would take it to a computer repair shop .
Oct 28, 2015 | ProntoTec Tablets & eReaders
Plantronics k100 loses connection and reconnects mid call how to solve this problem
First, try deleting the K100 out of your phone and, if you can, remove the battery from your phone. Once the phone reboots, try pairing the K100 back up to the phone and see if that resolves the issue.
Good luck from Headsets Direct!
Nov 28, 2011 | Plantronics K100 Bluetooth Headset
K100 not charging or responding
Here is something you can try. If you're still having problems and it's less than a year old, return it to your retailer for warranty replacement or call Plantronics at 800-544-4660 x5 x5538 for warranty service.
K100 Speakerphone: How to Perform a System Reset
1) Push and Hold the On/Off button and, without letting go, insert the charger.
2) Let go of the button as soon as you see a steady light on the speakerphone.
3) Unplug the charger.
4) Wait 2 seconds and turn the speakerphone on again.
Oct 01, 2011 | Plantronics K100 Bluetooth Headset
Plantronics k100 I have no volume.the only thing I hear is call ended.
One possibility: The K100 needs to be re-paired to your phone. When powering on the K100 it searches for the cell phone so you want to make sure your phone is in pairing mode and no other bluetooth device is interfering with the procedure so the phone within range can be connected by tapping the Multi-Function button.
Follow the link to the Plantronics K100 User's Guide for more help and instructions.
Sep 25, 2011 | Plantronics K100 Bluetooth Headset
When I first bought the product I had no problem pairing it with my 16 gig iPhone. Since replacing that phone with the 32 gig iPhone I have been unable to pair the plantronics K100 with my new phone. Why...
One possibility: If your new phone is paired but not connected because the K100 is looking for the old phone. When powering on the K100 it searches for the last connected cell phone. If the last connected phone is not within range, or the Bluetooth feature is turned off on the phone (which hopefully the first iPhone is turned off or at least out of range), then another phone within range that has been previously paired with the speakerphone can be connected by tapping the Multi-function button.
For additional help, Plantronics K100 Users Guide
Good Luck from Headsets Direct!
Jun 14, 2011 | Plantronics K100 Bluetooth Headset
Hi i can connect my ps3 to my tv 25vt-k100 what
You sure can, all you need is the RCA cables. it may not work very good but it shouldn't stop you from connecting it to the Sharp 25VT.
Just make sure you still have the Yellow/Red and White cable that came with the PS3, if you lost it or missed placed it, I am sure you can find one cheap on-line or any local electronic/video game store.
I couldn't find out if you have the RCA connections on the TV but from the pictures I found it looks like you have them in the front and it may only be the Yellow and white ones, but that should still work
Apr 14, 2010 | Sharp 25VT-K100 Combo
BATTERY DOES NOT CHARGE AND CHARGER DOESN'T LIGHT UP
If your charger is plugged into the outlet properly and you know it does work with other batteries, what you have is an internal open in your battery.
I have seen this happen, not sure what would cause it, but batteries can open up inside. Could be as simple as a cold solder joint inside where the batteries connect to the leads mounted on the case or worse. Either way, that is most likely your problem. Time to get a new battery if you know the charger is good. Other wise if the charger doesn't light up for any battery, then you have a defective charger
Sep 06, 2009 | Audiovox GMRS200W (14 Channels) 2-Way...
Plantronics K100 Bluetooth Headset Logo
24 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
