Question about Wmf/Usa 2.5qt Stainless Steel Perfect Plus Pressure Cooker
Change wmf handle - Wmf/Usa 2.5qt Stainless Steel Perfect Plus Pressure Cooker
How do I get the helper handle to stay on
Here is a review of the WMF pressure cooker, in the performace section (bout the middle of the review) are detailed step-by-step photos on how to get the handle on and off.
http://www.hippressurecooking.com/pressure-cooker-review-wmf-perfect-plus-rating/
Make sure that the red lever is pulled back when the handle is on and that it snaps back into place on the underside of the lid.
May 31, 2014 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
My wmf prestolino displays error code 187 when i turn it on. What does this mean ?
change the termistor from the top of the biger boiler with NTCM 10 ohm and that is the best solution 100% works
Nov 19, 2013 | WMF Coffee Makers & Espresso Machines
The pressure does not build up and the valve does not rise
There are photos of the WMF handle here. Make sue it is installed correctly, and the handle is in the locking position
Apr 02, 2012 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
I have a 3L 22cm wmf perfect cooker which leaks, can you help?
Make sure the gasket is in the right position, the handle is placed on correctly and the slide on the handle is in the locking position. Here are more details on how to use this pressure cooker.
Aug 24, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
Can I get a copy of Chinese user manual for Perfect Pressure Cooker?
Here are all of the pressure cooker manuals for WMF pressure cookers:
http://www.hippressurecooking.com/category/manuals/wmf/
Aug 18, 2011 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
No.1 part, the round whistle in the middle of the lid doesn't pop up when the cooker is on and pressure is building up instead the steam comes out of small pressure ball and it sprays everywhere.
Here are detailed instructions on how to use it. It sounds like the slide on the handle was not set to the locking position:
Mar 22, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
Wmf graphics filter missing! what is a wmf graphic filter?
Heres the fix, and it works!!!!
SYMPTOMS
When you start any of the programs listed at the beginning of this article, you may receive one of the following error messages:
One or more components are missing or broken. WMF graphics filter is missing.
Wmf graphics filter is missing.
CAUSE
This behavior can occur if the Windows Metafile (WMF) graphics import filter is damaged or missing.
RESOLUTION
To resolve this issue, rename the Wmfimp32.flt file:
- Click Start, point to Find, and then click Files or Folders.
- In the Named field, type wmfimp32.flt.
- In the Look in box, click Local hard drives, and then click to select the Include Subfolders check box.
- Click Find Now.
- Right-click the Wmfimp32.flt file, and then click Rename.
- Type wmfimp32.old.
- Press ENTER.
- Close the Find: Files Named Wmfimp32.old dialog box.
- Reinstall the program.
I hope that this helps!
Nov 30, 2008 | HP Pavilion a735w (PL308AAR) PC Desktop
Flash
Flash version 5 can save the movie as WMF sequence. You should choose the option:
File--->Export Movie---->WMF sequence.
You can't convert an swf file into a screensaver using Flash, or merely by saving it as a .scr file. You will need a separate screensaver making software for that.
Dec 14, 2007 | Adobe Photoshop 7.0 for PC
Wmf/Usa 2.5qt Stainless Steel Perfect Plus Pressure Cooker Logo
Top WMF Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a WMF Kitchen Appliances - Other Expert? Answer questions, earn points and help others
