Question about Tevion Televison & Video
Need a manual for tevion hd ready 46802
Need an instruction manual for 19 inch HD ready LCD tv EAN code 46802
  • 979 Answers
SOURCE: Sci Atlanta 8300 DVR HD sound in HD channels soft - analog channels OK
Experience has shown that with this relatively new mode of transmission, audio levels can be quite dynamic. If your set provides it, you may try turning on "Audio Compress" or whatever the name might be. Could also be called Dynamic audio also or some such. Reason for all the hubbub is that along with HD, mixing engineers are also providing the most range for the audio dynamics as well the most video composition info in the new broadcasts...Accordianman.
Posted on Oct 11, 2007
  • 579 Answers
SOURCE: SAMSUNG 19 INCH HD READY WIDESCREEN LCD TV LE19R71BX/XEU
We will need a list of the everything you tried.
Usually, this kind of thing is caused by hookup errors.
Posted on Jan 01, 2008
  • 110 Answers
SOURCE: Over air reception
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
Sorry I can't be of more help.
Good luck.
Posted on Apr 26, 2008
SOURCE: sky remote code
hi need code for sky+ remote to use on hitachi L42VPO1U
Posted on Feb 19, 2009
SOURCE: Trouble using Motorola DCH6416 HD DVR with standard def. tv
I fixed the problem! I found a posting on a message board by someone who had the same DVR and a similar problem. This person found a way to access a secret menu in the DVR to override the format which is automatically assigned. I followed the same steps to access the menu on my DVR and then tried changing a few settings until I found the ones that worked--changing the automatic setting from OVERRIDE to STRETCH and changing the output setting from 1080i to 480p. (It's pretty pathetic that no one at Charter could fix this problem!) Here is the link to the posting that I used: http://www.avsforum.com/avs-vb/showthread.php?t=1132766
Posted on Oct 02, 2009
My tv is showing status database empty. What do I need to do?
Main system control memory IC fault. Check and replace it. Contact any service technician.
Jul 09, 2016 | Toshiba 19DV616DB 19-inch Widescreen HD...
Remote control code for a 19"HD READY DIGITAL LCD
Hi Hazel,
The common codes used for Matsui TV are 098 and 178, however if these codes didn't work, please let me know the exact model number of your universal remote control to determine the right/other codes.
Kind Regards,
Mjsazon
Dec 16, 2011 | Universal Remote Control 10694 Remote...
Iwould like to know which cable i need for a 32 inch hd ready tv model number 30132 tevion.
An "HD ready" TV needs a SOURCE. You will need to get cable, satellite, or a converter box AND antenna.
Hope this helps!
Jun 13, 2010 | Televison & Video
Sky remote code
Jul 29, 2008 | Directed 434MHZ Remote Control
HD Ready or not ????
if it was mislabeled at the time of sale then you can return the tv. 480p only allows progressive scan to be used. 720 is the min hd you can run.
May 01, 2008 | Televison & Video
HDTV?
HD ready?? NO - - Compatible? Yes but you'll need the converter.. The US post office will be giving away coupons for the converter. Google search the HD converter issue and you'll have a wealth of information.
Bill
Feb 03, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Dec 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
78 people viewed this question
Top Tevion Televison & Video Experts
shaun taylor
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Are you a Tevion Televison and Video Expert? Answer questions, earn points and help others
