Question about Denon Audio Players & Recorders
DRA F109 How do you lock in a DAB channel?
Unable to lock in the various DAB channels
4 Suggested Answers
  • 395 Answers
SOURCE: right channel not working
check the pre out /main in jumper there should be a loop jumper for both left and right. if you are using a graphic EQ check the wires connecting to the receiver and the EQ. also is this happening on all sources?
Posted on Feb 07, 2008
marsrover
  • 682 Answers
SOURCE: the buttons to turn the
make system microprossesor reset according to your model.
---try to make system reset by disconnection and connection.
if all above failed bring a spray lubricant contact cleaner from radio shack and apply spray in volume and channel buttons,
Posted on Aug 18, 2008
SOURCE: My very old Denon AV Receiver (DRA-55V) works fine
check your speaker A - B channel push-button switchces. They tend to get worn and contacts internally corroded after all these years <!-- from fixya rte -->
Posted on Aug 16, 2010
My denon DRA-295 does not remember stations I set to memory when completely turned off. If on standby all goes well. A month after the problem mentioned above the tuner started to modulate reception and...
My better guess is a CMOS chip is either bad or there is a cold solder connection in the vicinity. If the power supply is bad, the receiver would not power up.
Nov 23, 2010 | Denon DRA-295 2 Channels Receiver
My very old Denon AV Receiver (DRA-55V) works fine except that one of the channels sounds 'gated' or thuddy and staticy...music is heard (in all sets of speakers and headphones) but quality in one channel...
Feb 21, 2010 | Denon AVR-587
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
Hi all i have a Denon DRA 455 with Eltax Linear 6.5 wich is 8ohms i have a sub but no sub output, apart from sharing power between them, how can i hook these up please? thanks
You did not state if your sub is a powered sub or not, but if you use the "B" channel for your sub, it should work. This is possible if the denon will work with "A" channel and 'B" channel on together. The back of the Denon should have two sets of speaker outputs. Connect the "B" channel speaker outputs to the sub. The "A" channel will still drive your 6.5's.
Aug 05, 2009 | Audio Players & Recorders
I want to know how many watts, the denon dra-375's output is? my brother-in-law gave me this unit and the cover's became diattatched off the back of the all the pot's. i am still in the process of putting...
The unit is rated at 120 watts total output ( 60 watts per channel x2 channels) As far as being worth fixing it depends on the price of the parts and what you want to do after its fixed. I looked around a little and the unit gets good reveiws from owners. They say its great for a "just music" system.
Jul 28, 2009 | Denon DRA-375RD Receiver
Cobra 25 uk ltd soundtracker locks up on channels
probably is the tuner chip or main board that gave troubles...assistance from expert only!
rgds, stefano
Jul 07, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Back channel turn off and on
Same problem with the 2.1 channel DRA-297. All sound cuts off and screen reads h/p input. I don't even know what that means. What's wrong here?
When it happens, the receiver makes a clicking noise. it goes back and forth from being on to h/p input shutdown. sounds like someone repeatedly flicking a lightswitch.
Thanks to whoever can help!
Jan 28, 2008 | Denon AVR-1700 Receiver
41 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
