Wirlpool wtw4800 top load not spinning and door lock stays loocked and light flashes
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 415 Answers
SOURCE: My frigidaire gallery front loading washer goes
are your clothes wet or do you see water still in the tub if so not pumping out the water to acheive the normal spin speed
Posted on Aug 19, 2009
SOURCE: Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Posted on Jul 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: door locked indicator light flashing
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: INDESIT WIXXL 146 washing machine ( please help
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 18, 2010
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
LID LOCK ON WHIRLPOOL WTW4800
The lock assembly has malfunctioned and needs to be replaced.
May 28, 2012 | Whirlpool Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Hotpoint WMA33 washer - door won't open
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Oct 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
