Question about Edirol UA-4FX External Sound System
Problems recording on acid pro 7 with edirol ua4-fx
I am having a hard time recording midi tracks on acid. i turn on my edirol effects before i record for audio tracks and when i play back the effects are saved in the track, but when i try with with a midi keyboard plugged into the edirol, the knob adjustments i preset on the edirol are not kept when i finish recording. when i try to play with input monitoring on and start a new track, the new effects are applied to the last track when i try to playback or record. i am pretty new to using software like this and if i could have any feedback i would be greatly appreciative
  • 86 Answers
Point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Posted on Jan 25, 2009
The Acid FX always says "No Track Selected " no
if you have screenblast 4.0 on more than one computer the track effects button must be purchased it says so in the manual. you can call support toll free 1-800-577-6642.
Dec 30, 2010 | Sony Screenblast ACID 4.0
I have a Fostex DMT-8vl 8 track digital recorder. Can I dump the tracks to Acid Music Studio 7 or Acid Pro 7 to save what I recorded in the Fostex 8 track, and will it go into seperate tracks? Thanks...
You can copy. You cannot just dump the file data. Unless you have an audio interface with multiple inputs, you can only copy 2 tracks at a time. Also, to sync the timing you'll need a midi port on the computer. Then you make the computer the "master" and the Fostex a "slave" device.
Jul 21, 2010 | Sony ACID Music Studio 7
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
Recording second track
have you tried pressing the record button on the first track arm to stop it recording?
Jul 04, 2009 | Sony Acid Music Studio 7 Full Version for...
Tascam 144 sony acid pro 6 no sound from midi track
It sounds like you may be confused on what the MIDI part actually does. MIDI records your performance, not your sound. Then you assign and play back the recorded performance to either a virtual instrument (in which case you should here sound from your computer) or to a real physical MIDI capable instrument (in which case you would here the sound coming from that real instrument instead of the computer).
The ends of the MIDI cables themselves are identical, not IN or OUT.
Feb 01, 2009 | Tascam US-144 Sound Card
Recording midi player
Yes. You can record the midi output to a track using bounce mode.
With you midi (or smf) file loaded into the midi tone generator,
press shift-bounce to enter bounce mode. Then arm a track for recording. Turn the fader up for that track, the master fader and the fader for the midi tone generator. Make sure than all other track faders are down or the tracks are muted (or empty) and press play and record. The midi song will be recorded to the track in real time. Just press 'stop' when done and exit bounce mode (by pressing the bounce button again).
bd.
Jan 12, 2009 | Tascam 2488 Portastudio Multitrack...
Bouncing a MIDI track to audio
Remember midi doesn't store notes only midi codes. There are some converters that do this.
Try this:
http://www.zamzar.com/convert/midi-to-mp3/
Oct 08, 2017 | Sony Acid Pro 6 Professional Music...
Problem with playback
Hi, I have the same audio interface. Alright, make sure that all of your effects are turned off. you probably (and most likely) have the "fx voice", "amp drive", "chorus" and "delay" effects turned on (bottom row). There is no way you should have distortion with tremolo & reverb on playback all the same time without the effects being turned on. the pop ticking could be produced by the buffer size. If youre using Sonar LE, you should tweek the buffer size until playback sounds smooth. I hope I helped! Good luck!
Aug 14, 2007 | Edirol UA-4FX External Sound System
Acid Pro 5
http://www.custcenter.com/cgi-bin/sonypictures.cfg/php/enduser/std_alp.php?p_sid=ZSQmvAwi&p_lva=&p_li=&p_accessibility=0&p_page=1&p_cv=1.92&p_pv=2.272&p_prods=7%2C272&p_cats=92&p_hidden_prods=&prod_lvl1=7&prod_lvl2=272&cat_lvl1=92&cat_lvl2=0&p_search_text=plays+track+on+track+2&p_new_search=1&p_search_type=answers.search_nl This is the Sony site choose Acid 5 and they have volumes of info. Hope that helps. Good Luck Tim
Mar 14, 2007 | Sony ACID Pro 5 for PC
Edirol UA-4FX External Sound System Logo
706 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
