Question about Samsung RS2630SH Side by Side Refrigerator
Fan motor IS-27210SCD6A - Samsung RS2630SH Side by Side Refrigerator
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Where is the best place
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on Sep 18, 2011
The fan on the inside ac unit wont come on is there a reset button
One of the common problems in air conditioners is fan motor bearings going bad and the fan motor shaft is locked up stalling the motor or preventing rotation. Another cause of fan motors not running could be the motor start capacitor. The capacitor is needed to give the motor a jump start to get it rotating. If you can get access to the fan squirrel cage and can spin the fan ok, the motor bearings are then good. Most likely the problem then is a bad motor start capacitor that can be replaced. In very rare cases the motor winding itself could be bad and the fan motor will need replacement. regards, Dennis
Feb 27, 2015 | Heating & Cooling
How to replace fan motor
Which fan motor you are asking for, you have 3 fan motors built in on you vehicle, 1. Main drive radiator fan has no motor, 2. Condenser or auxillay fan motor located at front right side of radiator assy. Evaporator motor located under your dash board assy.
May 24, 2014 | 2007 Nissan Frontier SE Crew Cab
LIGHT, turntable, and fan don't come on
follow this test and fix it. God bless you
  1. Exhaust fan motor If your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. Thermostat Another part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control board If your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Dec 09, 2013 | GE CVM2072SMSS Microwave Oven
Want to change fan on blower heater
Removal
  1. Remove wiper arms.
  2. Remove cowl panel.
  3. Disconnect blower motor electrical connector and vent tube.
  4. Remove blower motor retaining screws.
  1. Remove fan retaining nut from blower shaft through plenum opening while holding the fan from the engine compartment.
  2. Remove fan from blower motor while removing blower motor from vehicle.
Installation
  1. Hold fan through plenum opening.
  2. Install blower motor to vehicle while installing fan to blower motor.
  3. Install fan retaining nut to blower motor shaft through plenum opening.
  4. Install blower motor retaining screws.
  5. Connect electrical connector and vent tube.
  6. Install cowl panel.
  7. Install wiper arms.
Aug 13, 2013 | 1991 Oldsmobile Cutlass Ciera
Galaxy box fan juss stopped while plugged in still. Cleaned the dust from fan as best as possible down to its motor. Replaced the parts taken off the fan then plugged it back up only to get the same...
hi Ryan.
How to Fix a Box Fan. Box fans work by having a set of fan blades attached on the shaft of a small motor. The motors and bearings on box fans have a tendency to go bad. Here is how to fix a box fan.
Step 1 Take apart the fan by removing the screws on the front panel of your fan and lifting the blades off the hub.
Step 2 Test the switch on your box fan by setting your volt-ohm meter on RX1 and removing the common switch lead from its terminal. Insert one of the probes into the terminal. Remove the other switch leads and insert the second probe into the terminals. Test each terminal one at a time. All readings should be drawing zero ohms. If they aren't, you will have to either replace the terminals, or if you can't replace them, you will have to replace the fan.
Step 3 Service the motor on your fan by lubricating the motor using SAE 20 non-detergent oil. Apply one or two drops to each oil port. Test the motor to see if it is working.
Step 4 Spray the shaft near the motor housing with a lightweight spray lubricant, if your motor is running slowly. Lubrication usually helps.
Step 5 Replace the motor on your fan if your efforts to clean the motor do not work. You can replace the motor by unscrewing the motor parts, taking the old motor to your local electrical store, purchasing a new motor of the exact same model and installing the new motor.
Step 6 Put your box fan back together the same way you took it apart.
How to Fix Box Fan Hunker
http://www.instructables.com/id/How-to-rejuvenate-a-box-fan
Galaxy box fan just stopped Google Search
Dec 21, 2017 | Refrigerators
Im on my 2nd big buddy and both of them the fan has gone out, the first on went in a week, and this one last a couple of months.
fans
1. oil the bearings,sae 30 or wd40 for places you cant get into.
dont take fan motor apart unelse you realy have to.
dont let your fan motor bearings get worn egg shaped from lack of oil.
2. make sure fan blades not hitting or scraping fan housing and fan blades are securely fastened to fan motor shaft.
3.mr heater fan motor is 12 volts DC , so it may have a segmated comutator and brushes.
I dont know because i have not yet needed to take my mr heater
fan motor apart but i have worked on hundereds of ac fan motors
in the past 65 years.
4. keep fan motors from getting wet. they hate water.
5. keep fans clean, they dont like foriegn materials.
Your specific problem: first fan 2 weeks,second fan 2 months.
how much you use them, are you wearing the brushes down?
Getting fan motor wet? foreign material getting pulled into fan or fan motor? off/on switch work ok. batterys good,battery contacts ok? fan transformer 110 vac to 12 vdc good? fan bearings oiled?
need more info to diagnose properly.
all of the above needs to be checked out to tell whats happened.
fan & fan motor needs to be inspected.
Feb 21, 2011 | Mr. Heater Big Buddy Heater
Hunter fan model 25706 both the lights & fan have stopped working
mcdevito75 here, VeryGood question, very good, here we go, ------ First a re-set for the motor, I really don"t know but if there is it"s on the motor itself, you"d have to un-screw the cover just at the ceiling and let this cover slide down the chain Attached from the ceiling to the fan itself. and check the motor itself for a reset swtch, usually a red bitton. Now!! true, if the fan motor is bad it could affect the lights, here"s how, the wall switch supplies electricity to the fan motor and the pull chain on the motor turns the fan on, from the motor itself to the fan lights another wire also from the fan motor goes to the fan lights, SO!! if the fan motor is no good it won"t allow electricity to go on to the fan lights. Maybe you Fan motor is just stuck, specially if you haven"t used it in a whlie, with the wall swiotch on and fan speed on low try to gently move the fan blades them selves. If not you may have to repalace the fan.
Jul 18, 2010 | Hunter Ceiling Fan Light Switch Control
Ricoh afico 401
It is a cooling fan that has died.....I copied the following directly from the service manual. It's been a while since I've seen one of these machines, but the fan is either inside the rear panel, or accessible through either side (wherever there are vents in the panels basically). If you're at all technically inclined you can usually tell which fan it is by simply spinning it, and if it's not free, it is trouble...fairly standard fans, as long as you get the proper direction of airflow, and similar amps.
SC490: Ozone fan motor lock/Exhaust fan motor lock
-Definition- [B]
A fan motor lock signal is detected for more than 0.5 second from
either fan.
- Possible causes -
· Ozone fan motor defective
· Exaust fan motor defective
· Poor connection of the fan motor connector
· Something is stuck in the fan motor
Feb 12, 2009 | Ricoh Office Equipment & Supplies
57.70 error for hp colorlaserjet 9500n
this is the fuser fan error replace them ur problem will be resolved
Nov 25, 2008 | HP LaserJet 9500n Printer
Samsung RS2630SH Side by Side Refrigerator Logo
215 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
