Hi i need to replace my ink but not sure where they are
  • 837 Answers
Give me your make and model and I can help
Posted on Jan 22, 2009
EPSON PRINTERS
Hi, i am sorry you are going through this. Shake the ink properly before inserting it and make sure you are using the right ink, more so, the inks you bought "might" be outdated. Which could cause the printer not to recognize the ink..... Here mail me directly if you are still having this issue and i will tell you steps to follow if need be replacing the Ink Head.
Regards
Dec 03, 2013 | Epson Office Equipment & Supplies
Printer says offline and cartrige light is flashing
Check whether the ink cartridges are properly installed.If installed incorrectly they can cause the printer to go offline.Install them correctly.
Also check whether you're running low on cartridges ink and replace if need be.
Sep 27, 2011 | HP Deskjet 6940 InkJet Printer
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
Hi Folks: I would appreciate any help and suggestions: HP DesignJet 1055CM error 0A0020 006501D1 Thanks, Paul
"Error in calibrating the APS sensor"
APS= Air Pressure System - it provides air pressure to pump in to the ink cartridges, thus pumping ink to the printheads through the ink tubes.
First things to try
- Remove all Ink cartridges.
- Power down printer.
- Power on.
- Place cartridges in ink supply station, check if they are recognized.
- Replace the one cartridge that is almost empty.
- Check all cables and air tubes in the ink supply station. (you need to remove left cover of printer)
Make sure they are all properly connected and not damaged.
Make sure the air tubes are free running - NOT pinched or bent!
- Lastly,
When all above fails, replace faulty APS sensor and / or pressure valve.
Oct 30, 2010 | Computers & Internet
I replaced the black ink cart. but the ink light still blinks. do i have to replace the color cart also? or what else could the problem be? thanks so much
Hi:
I would say replace them both, but first make sure you removed the print head protectant strip from the cartridge. Go into you printer properties and check your ink levels to see if the color is empty, also make sure you use HP ink cartridges, off brands do not meet the required spec's all the time. And never use ink refill for cartridges as sometimes the ink they use is to thick for the HP Printer.
Dec 02, 2009 | HP DeskJet 932c InkJet Printer
Xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
  1. Make sure you are using Phaser 8500 ink sticks
  2. Make sure the ink sticks slide properly
  3. Remove any broken or partial ink sticks from the ink-loading bin
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at www.xerox.com\support
Oct 24, 2009 | Xerox Phaser 8500/DN Printer
Replaced only black -- will it work without a new colored ink cartridge? Resume light keeps blinking.
hi both of your inks need to be installed with ink in if there is one with no ink like the color the printer will not work, you will have to wait until you have the color.
May 20, 2009 | HP DeskJet 648c InkJet Printer
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
Say's the ink try is dirty so won't print
Hi lovely michelle,
Are you sure this message appears in your computer?. I never heard such message in my long time as service engineer. Did you mean 'The ink tank is empty' ?. If this message appears means the ink has run out and need replacement to continue printing. Hope this help you. Have nice day lovely Michelle.
Regards,
Source:
Canon Inkjet Forum
Dec 09, 2008 | Canon PIXMA iP1600 Printer
23 people viewed this question
jasbo
jasbo
