Question about Jensen VM9020TS Car DVD Player
AVH-P5000DVD SOUND BUT NO PICTURE
I have a Pioneer AVH-P5000DVD installed in my car. All functions work well except for dvd (for both regular dvd and divx files). The movie plays and I can hear sound but no picture of the actual movie. I can use the touch screen and the menu will come up but the movie picture remains black. It feels like the movie is playing in an external location if I had television screens in the head rest but I don't. I am not sure how to make it come up on the screen in dash?
5 Suggested Answers
  • 4102 Answers
SOURCE: pioneer avh-5700 dvd
Hi you need to unwire it all and leave it off for 24 hours this will reset any problem you have.
It sounds like it is wired up wrong somewere you can wire it direct without the brake this will also allow you to play dvd whislt driving this way passengers can watch dvd whilst driving also you will need to check all the wires as your problem sounds like either a wire wrong or the system has shorted out if this is the case and it has shorted it is going to be hard to get repaired and also expensive so iwould try unplugging it for 24 hours and then rewire it checking everywire is in the right place.
If you are 110% sure that it is wired up properly then the chances are the unit itself is damaged.
When you wire it back up make sure you do all the wires at the same time dont chage one after as this can cause the unit to malfunction give this a try and let me know how you get on ok
Posted on Dec 01, 2007
SOURCE: Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
Posted on May 28, 2008
  • 91 Answers
SOURCE: pioneer AVH-P5000DVD
I had the same problem, you will only be able to play DVD's from your region.
Posted on Jun 17, 2008
tech48
  • 624 Answers
I am sorry to tell you, but this model is only set up for region 1.
I checked the service manual and it only gives region 1 as an option.
If you were able to change the region, it would give the other regions as possible options.
There are some DVD players that will let you change the region a couple of times before it would lock into a region, but this is not one of them.
I work at an authorized Pioneer repair center, so I have access to all of Pioneers service information. I have repaired a few of these exact models and never came across any menu functions that would allow you to change the region.
Despite the not so good news, a good rating would really be appreciated.
It motivates us to answer questions that may not have a very popular answer.
Have a great day and let me know if you need any further assistance.
Posted on Jun 22, 2008
SOURCE: Pioneer AVH-P5000DVD stereo USB Error 23
You have to disable the U3 launchpad on the cruzer usb stick, but you should save the launchpad.zip somewhere if you want to reactivated the U3 features again.
There should be a file called U3 or launchpad uninstall. Run it, put your wavs mp3s accs etc. on it, love it.
Posted on Nov 18, 2008
Tip
Some information of DVD player for Audi A6
Audi always be a kind of luxurious and comfortable car, but the technological develop fast , the original function can't not meet the driver need now. So the special made Audi A6 DVD player come out. There is some information of Audi A6 DVD player for you.
The outlook of Audi A6 DVD player match the Audi completely. People will not think that the Audi A6 DVD player is not the original DVD player. The resolution of 800*480 will display the high effect of picture for you. The operation system and capacitive touch screen always make the operation easily.
The Win CE operation system can be operated easily. The Audi A6 DVD Player can react quickly. And the you can play audio and video by most of format. It will provide a high quality display for you. The Bluetooth function also help people a lot. If you want to connect some device you can find USB port in the side of Audi A6 DVD player which is the place you reach easily. you can surf by WiFi and 3G internet.
Hope these tip can help!
Audi A6 DVD Audi A6 Navigation Audi A6 GPS Audi S6 Navigation Audi RS6...
on Jun 17, 2014 | Car Audio & Video
How to reset eclipse avn51d?
www.eclipse-web.com/us
Jul 13, 2014 | Car Audio & Video
Master reset for kenwood kvt-614
The reset button is just to the left of the volume control. See the picture in the downloadable manual at... http://www.manualslib.com/manual/86153/Kenwood-Kvt-614.html
Jul 02, 2014 | Car Audio & Video
My ripspeed incar dvd player has got no picture but has got the sound what can i do to make this work
First thing comes to mind is a possible update to the system. Have you had it for a while now? If so, you should go to the computer and go the maker of the unit. Check under software updates or downloads to see if there has been a remedy or fix that the maker has published, if so...then do as it says to do and see if this resolves the problem before you get into the actual technicals of the unit. It may need nothing more. I hope this helps.
May 18, 2014 | Car Audio & Video
DVD won't place discs
Did that just begin out of nowhere? IS the Dvd spinning, if you listen closely and the player is making noise as well? That would be the lens trying to get a read on it but if it's scratched (I'm sure you tried others) sometimes the lens just go bad out of nowhere...Mu original 500 Sony PS1 in 1998 lost its lens about 3 months in...I can't think of anything else right this moment....I hope you fix it...
Mar 23, 2013 | Car Audio & Video
It does not turn on no sound
Check the fuse for the radio.
Mar 20, 2013 | Car Audio & Video
Usb
You need a new USB cable the new Kenwood and pioneer headunits have to have there own USB cable, go to you local audio dealer or go online and get a pioneer USB cable, they run $24 , I got my Kenwood one and they just have the option of total control from the headunit or not
Nov 16, 2012 | Car Audio & Video
Jensen VM9020TS Car DVD Player Logo
148 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
