Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet WFW94HXR Front Load washer Manual
SOURCE: washer won't drain Whirlpool Duet GHW9150P Front Load Washer
I recently had the same problem.. There is usually a panel on the lower front of the washer. I flipped open the panel door and removed the screw out plug. Make sure you have a floor drain at this point, as the water will come out when the plug is removed. This plug also contains a filter. It was plugged up with all sorts of debris... Lint, dryer sheets, rubber bands, a stick ect ect. I just cleaned the filter and plugged it back in. The washer worked normally after this. This is a simple thing to try before removing the back panel and drain hose to check for obstructions. The solution by jsrock516 would be the next logical solution. After that I would think that a faulty drain pump would be the problem
Posted on Sep 20, 2008
SOURCE: Service manual
Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
Posted on Oct 03, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 7 Answers
SOURCE: Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Posted on Feb 15, 2009
  • 662 Answers
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Posted on May 19, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
How do i reset front panel on my whirlpool washer front load duet
Hi
Its a simple procedure to reset the Whirlpool Duet front load. Please press and hold the END OF CYCLE button for 15 seconds to reset. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I tried to start a load and an F-1 code flashes. I have a Duet Sport front load washer (2 years old).
Go to the Whirlpool webside and download a manual for free. They are good folks.
Here is mine...
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
G.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I change the pump on a whirlpool duet washer - specifically, how do I get the clips off of the hoses?
his Duet manual should help you.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Oct 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have a whirlpool duet front loading washer. Recently bought a new house, only way to access basement is up 5 steps on side of house to landing with railing.cannot turn machine on landing so door is facing...
This may or may not be helpful but please see the following Whirlpool installation and service manual for the Duet Sport washer.
It has a number of sections on accessing components and you may be able to determine how to take the front off.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Following is the Whirlpool service manual for two other models of the Duet washer.
Oct 20, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Service manual
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
