Question about PaceMaster Silver Select XP Treadmill
Treadmill is turning off when running and need to reset circuit breaker
Circuit breaker on the treadmill itself.
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My treadmill no longer asks me for my weight, and I'd like to reset it.
go to reset. Turn off the power and reset the button too. Try again.
After that RUN the software calibration for easy diagnose, troubleshooting and fix it.
Happy New Year. God bless you
Posted on Jan 01, 2013
ercupa190
  • 12223 Answers
SOURCE: Bronze Basic Treadmill Your question about Bronze Basic Treadmill has been posted. i have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks s
yes there are some reset button see your owner manual and do it. if you do not have owner manual download for free
LUBE the deck belt and rollers bearing inmediately.
www.fitness.manualsonline.com
Posted on Jan 02, 2013
  • 7 Answers
SOURCE: Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Posted on Feb 19, 2013
Why did my treadmill stop abruptly while in use?
Your assumption is correct, if you have a household circuit breaker popping, you have a short or over current situation. If you have too many other things plugged into the same circuit you could be overloading that breaker. Depending on how your home is wired, you could have a few (older homes may have quite a few) outlets feed by a single breaker. If you have used the treadmill in that outlet (with the same items plugged into that circuit), the breaker it's self MIGHT be going bad (popping at too low of current).
For safety, inspect the power cord, for any damage, and be replaced if there is any.
If the power core is undamaged, I would try plugging the treadmill in another circuit. Choose an outlet that was not affected when the breaker popped. It you use an extension cord to get to another outlet, be sure it's rated for enough current. If it still pops the same breaker it's the same circuit, and you need to plug it in somewhere else (probably in another room). If a different breaker pops, then the short in in your treadmill. At this point you will need to know something about electricity to further isolate the short.
May 19, 2014 | Endurance T3 Treadmill
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
I have a proform 300 treadmill. we moved into a new home and it just stopped working. it was perfectly working before the move. now, nothing comes on, no power, nothing.
Dear Sir:
I will help you.
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
2) Circuit Breaker:
Please check the circuit breaker from the main panel, and reset, or put some Lamp for to see if turn on. if do it. the problem could be the wires and the plug, Test it with A VOM(Voltimeter) for a continuity.
Thank you in advance, sincerely.
If you need extra help, please do not hesitate to reach me. .
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Proform 810 TR Treadmill
The power is on but it won't run
Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Thanks for the rating Good luck
Dec 22, 2010 | Exercise & Fitness
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
We just bought the floor model of the weslo cadence 58 treadmill and it wont work, we have the key, but it is not working. is there a switch we should be turning on to get it to work?
Plug in the power cord . Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then put your safety key and it should start up for you.
May 03, 2010 | Weslo Cadence Ct 5.8 Treadmill
Will not power on
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
Apr 30, 2010 | RTO Lifespan Fitness Tr 2000 Hrc Treadmill
I left the red key in epic view 550 for 1 full day, next day when discovered now treadmill will not start, no lights, no noise, nothing!! Help
Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch to the reset position.
Apr 30, 2010 | Epic View 550 Treadmill
How do I turn off my Reebok 8050 ES? I can not figure out how to turn it off when I am not using it.
Plug in the power cord. Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset
Apr 20, 2010 | Reebok 8050 ES Treadmill
PaceMaster Silver Select XP Treadmill Logo
Top PaceMaster Exercise & Fitness Experts
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Electro Med Services...
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
