Question about Garden
Lgt 14d oil specs
What weight oil?
3 Suggested Answers
jpolicky
  • 40 Answers
SOURCE: I need specs.
Engine Oil SE Class SAE 10W40, 10W50, 20W40, 20W50
w/Filter Change 4.0 liter
No Filter Change 3.5 liter
Level On center stand, wait 5 min, middle of window Left side of engine case cover
Final Gear Case Oil
Above 5°C API GL-5 SAE 90
Below 5°C API GL-5 SAE 80
Capacity 0.2 liter
Level Mcy vertical, to bottom thread of filler cap hole left side of rear wheel
Engine oil and trans oil are the same
Posted on May 26, 2009
Molson02536
  • 3854 Answers
SOURCE: fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
Posted on Feb 09, 2010
What's the valve lash to be lgt14d
Darrell, Did not find the lash specs. Attached links are to a manual and forums that could probably give you the lash info. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ford LGT14D LGT16D Lawn Tractor Service Manual LGT 14D0 results You may...
TractorData com Ford LGT 14D tractor information
LGT14D Hard Start me not diesel person MyTractorForum com The Friendliest...
Ford Lgt 14D Diesel Garden Tractors Repower and Conversion Forum
May 07, 2016 | Cars & Trucks
What type and brand of diesel engine oil should I use and also transmission fluid to buy is blue smoke coming from exhau
All ways follow the drivers manual, It will show a lighter weight oil for cold climates and a higher weight oil for hotter climates . Brand of oil is not important , specs are, try a good injector cleaner such as Inter-Ject clean and cure, for a smokey exhaust.
Aug 06, 2015 | Cars & Trucks
How much fork oil goes in a 1981 Honda xl500s
10w weight oil
Can't find the quantity anywhere on google..
Motorcycle Specs
Sep 11, 2014 | Motorcycles
What oil to use for a 10 year Ford Focus 2003
Generally speaking, we do not make recommendations on products by brand. Any of the brands you mentioned will meet the factory specs.
If the car has over 100,000 miles, you could bump up the weight to 10w-30 or 10w-40. Or stay with the factory recommendation.
The low number is the weight of the oil at zero degrees, and the high number is the weight at 200 degrees.
Keeping the oil and filter changed is more important than the weight.
May 10, 2013 | 2003 Ford Focus
Specs and oil capacity
Most owners of the old Ironheads try to use the oils that were used when they were built. They use straight 50 weight when the weather is cold and 60 weight when temps are hot. But, one could use 10W50 oil in them. I would not use synthetic as any oil leaks will intensify with the use of synthetic oil. The XLH, XLX, and XLS tanks hold three quarts with the exception of the XR1000 which hold two quarts.
Jun 20, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Just purchased vehicle and don't have an owners manuel for maintaince specs.
Haynes manual 24071 covers the new style S-10, Sonoma, Blazer and Jimmy. It will give you all specs for the motor, transmission, and any other options. I have a '91 S-10 and a '96 Jimmy. All specs from Oil Type, Transmission fluid type, and the weight of gear oil needed are included. It also offers step by step instructions on how to perform most repairs and tourque specs on almost all bolts. Good luck and wise choice on vehicles.
Feb 03, 2010 | 2001 Chevrolet S-10
What kind of oil should I use in Florida. Truck leaks a lot.Would a heavier oil help with limiting leaks?
You could use a straight weight SAE 40 or 50 in a warm climate like that. The heavier oil shouldn't run out quite as fast.
Dec 04, 2009 | 1990 Dodge Ram
I need specs.
Final Gear Case Oil
Capacity 0.2 liter
May 26, 2009 | 1998 kawasaki VN 1500 Vulcan Classic...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
