Question about Xerox Phaser 7300DN Laser Printer
Phaser 7400 waste toner auger assembly - Xerox Phaser 7300DN Laser Printer
  • 2072 Answers
SOURCE: Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Posted on Mar 07, 2008
SOURCE: replace waste cartridge on Xerox Phaser 7400
I just fixed mine. You need part #604K47890 Gear Coupling Assembly Kit. Cheapest I found was $6.99 at www.sparepartswarehouse.com plus $13.95 s/h. Remove the waste cartridge & you can see the white plastic gear. I tried to disassemble the printer (using service manual) in order to replace this part. Good luck. It looks like you need to take the WHOLE thing apart. Easier method is to get a drill or dremel & grind away the thin metal to make the whole slightly larger. Just be careful with the dust/particles. I did this & it worked perfectly.
Posted on May 02, 2009
  • 110 Answers
SOURCE: Phaser 7400 LCD is blank. How can that be fixed?
Once the LCD is gone blank that means you have to change the control panel. it's not difficult to change, all you have to do is remove the covers that are behind the the control panel. Once you have removed the white covers you can now unscrew the metal hinges. Then you have to insert a flat head in the small cracks behind the control panel that opens the control pane blue covers. Now you disconnect the data cable that connects from the control panel to the machine and that's it. Hope this helps
Posted on Nov 02, 2009
SOURCE: how can you reset the waste toner counter?
Exactly the same problem over here ;-( When replacing the toner recently i forgot to switch of the power, so no reset. I can't find the reset option in the menu, resetting aal settings did not solve my problem.
Posted on Feb 23, 2010
corokke
SOURCE: xerox phaser 7400 replaced yellow toner, but still
This happened to us today --- really frustrating! We ended up changing the Yellow Imaging Unit early (it was 'close to end of life') and now the yellow toner is all happy & full again. . .
good luck to you!
Posted on Apr 12, 2012
Why is my Phaser 7400 printing a solid pink page? The Transfer unit is half pink. Is this why?
This may be a high voltage problem.
Am not familiar with this machine but is a generic fault.
Ensure contacts to drum/cartridge are clean.
Next
If possible, unplug machine, open up and ensure all high voltage connections are good.
Good luck.
Jul 24, 2015 | Xerox Phaser 7400/DXF Laser Printer
Error code 929
Pls check the Wast toner full. or not and check wast duct assembly,
that assembly spring was damaged, pls replace duct assebly and change new wast toner,
Mar 11, 2014 | Xerox Phaser 7400/DXF Laser Printer
Phaser 7400 error 929
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
Jan 13, 2012 | Xerox Office Equipment & Supplies
I am getting error code L4-02. Any solutions?
L4-02 - Drum Motor Lock.
  1. Remove the process unit, remove the drum & check the waste toner auger & gear assembly.
  2. You will probably find this is seized or broken due to excessive drum cleaning.
  3. When changing the drum & developer, you must reset the rotation counters as well as the drum/dev counters. Otherwise, there is excessive over-toning, leading to waste toner filling the toner cartridge waste area too quickly & therefore leading to waste toner auger assembly blocking up.
  4. You will probably need a new process unit as the auger drive gear has been known to break off the frame.
  5. There is new firmware for this problem. Have a service professional update the firmware for this device and the problem will be gone.
Feb 16, 2011 | Sharp AR-M355U Copier
How do you empty the waste cartridge on the phaser 7400?
it's a simple you respect clean inside of the waste reservoir by a solvent nettoyant with water for twice Remarque : le non-respect de ce mode d' emploi/des consignes de sécurité peut entraîner une mise en danger
Oct 13, 2009 | Xerox Phaser 7400/DXF Laser Printer
Phaser 7300N - Where is the waste toner container?
That machine does not have a waste toner container like the xerox phaser 7400. What it does is all the waste toner is cleaned at the IBT belt. If you remove your IBT belt part number 016-2000-00 you will see there is a plastic container at the end and that is where the wast toner is.
Oct 13, 2009 | Xerox Phaser 7300DN Laser Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Phaser 7400 not printing red
I would suspect you do not have drive to the red imaging unit area. A gear may have fractured, a motor not runing, which would normally give you a fault code, or a clutch is slipping not driving the red components.
Jul 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Phaser 7400
The closest I can find to your description is a U6-0 and the suggestion is to replace the transfer belt assembly,
Feb 11, 2008 | Xerox Phaser 7400/DXF Laser Printer
PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Apr 03, 2007 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
161 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
