Question about GE Spacemaker JVM1640SJ Microwave Oven
We need a schematice for a jvm1850-jvm1851-jvm1860 it is a xl1800 we do not know the fuse is. do we have to take the uint down it is mounted under the cabinet.
  • William Miller
    William Miller May 11, 2010
    Is it dead, meaning no
    display, no light when you open the door and no beeps when you press a
    pad on the keypad?
    Is the outlet working?
    A microwave can be dead
    for many reasons.
    It
    may be the fuse, which is usually located behind the grille, on
    the
    floor of the oven behind the control panel, between the door switches,
    or on the filter board near where the cord comes into the unit.
    If
    the fuse is good, it may be an open thermostat or thermal cutout (TCO)
    / thermal fuse on or near the magnetron or on top of the cavity / body
    of the oven.
    If it goes dead for a
    while during or after cooking
    then comes back on, the magnetron is probably overheating and causing
    the magnetron thermostat to open.
    Then when it cools, it
    closes the circuit and allows power through again.
    When
    checking TCOs or thermostats, if it has a hood fan thermostat,
    that should read
    open, as opposed to the others, which should read closed.
    So don't let that fool you.
    If the cavity thermostat
    needs to be checked or replaced you'll need to pull the oven from the
    wall.
    If
    so, the installation instructions are very handy, and it's best to have
    two people since the microwave can be heavy and awkward.
    You can download GE
    owner's manuals and installation instructions
    here.
    If it went dead almost
    immediately after pressing the Start pad, that's usually a shorted
    high-voltage capacitor.
    If it went dead several seconds after pressing the Start pad, that's usually a failing
    high-voltage transformer.
    If
    it goes dead or blows the breaker (or GFI) when you plug it in or open
    or close
    the door, then there's a problem with a door switch or door switch
    mount.
    If it's intermittent or
    random, it may be a bad
    connection, usually on the control board or a loose fuse holder, or
    even an intermittent fuse.
    If you or someone you
    know
    decide to look into it, we have critical safety information and
    disassembly information at our site, and our link is at our listing
    here on FixYa.
    There
    should also be a "mini-manual" hidden inside the unit behind the
    control panel or hidden on the left side behind the grille, which is
    very
    helpful
    when troubleshooting & testing.
    At
    our Web site, we have a video
    available showing how to remove a typical
    over the range control panel assembly in under 5 minutes.
    You can usually find
    helpful exploded view diagrams and order parts by entering your full
    model number
    here.
    We're
    happy to help you with free advice and we'd appreciate your thoughtful
    rating of our answer.
  • roberto serbin May 11, 2010
    You did not say exactly what your microwave is doing or not doing?
    President:
  • 1,734 Answers
Ask the schematic finding experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
My jvm 1861 oven does not power on at all. how do i disassemble the control panel to replace the fuse
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
The fuse should be accessible after removing only the grille, with no need to remove the controller.
According to a similar model's service manual:
"The fuse is located on the upper duct mounted to the Noise filter.
1. Disconnect power and remove grille.
2. Replace the fuse."
You can find handy exploded views and order parts by model number
here.
May 25, 2011 | GE JVM1860 Microwave Oven
Oven display flickering and when I open door the light flickers and makes a sound
I'm guessing your model number is JVM1850- or JVM1860-series microwave.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee. Details are here.
Jan 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL 1800; Model JVM1860 CD 001; Manufactured Nov. 2001 When opening the door or pressing any menu option, a constant buzzing sound occurs. The unit does not respond other than the...
We see (and repair) this a lot. The problem is electrolytic capacitor that fails on the control circuit board, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year repair guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 22, 2010 | GE XL1800 1100 Watts Microwave Oven
It seems as if it makes a buzzing noise when the door is opened and the light does not seem as bright as usual... sounds like the noise is coming from the light area ??
I'm guessing it's a model JVM1850- or JVM1860-series oven?
We see and repair this problem a lot with our $39.95 service with a one-year guarantee.
Nov 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where is fuse located in microwave
Yes but need the model number to help you know where it is.
Aug 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heat when Microoven is turn on. GE XL1800 Spacemaker
If there is a loud humm the magnatron tube has gone bad. and some times there is no humm at all but i would say its the mag tube has gone out.
Jun 13, 2009 | GE JVM1850 1000 Watts Microwave Oven
Microwave does not work
please dont forget to rate me on this issue...
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
335 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
