Unable to update my protection after uploading new 2009 Micro Trend Internet Security package using a 64-bit operating system. Error message advises to check my proxy settings. I've done that. System is set for automatic import of this info, however, I went ahead and entered the IP address, etc.. but still no success. The system is even set to revert to the old settings if there is a glitch with an update. Evidently, that command isn't working either. I don't know what to do next.
  • Anonymous Mar 31, 2009
    The company selling ths micro trend security must be held reponsible for selling us defective, and must return our money.
    I bought a computer, and the security software a few month ago , I tried to do millions things to fix it. Still it says unable to update.
  • Meph1234 May 11, 2010
    Can you disable the proxy all together to get a direct connection to the internet?
    Perhaps you are behind a firewall that blocks the specific ports that the program needs. Maybe you need to use port forwarding on your router in order to connect.
    Sorry about all the maybes, im not 100% familiar with the program.
This is the resolution i got from trend micro regarding this error. it worked for me, so i thought i should share: I have reviewed your case and I understand that you are getting an error message that says “Unable To Update Your Protection” when updating the Trend Micro Consumer Product. With regard to your concern, this problem happens if there’s a missing component in your computer’s Registry. Let us configure the registry of your computer using the Registry Editor of Windows. Refer to the following. 1. Click on the Start button or the Windows Orb Button. 2. Windows XP: Click on Run then type regedit on the text field then click on the OK button. Windows Vista: Type regedit on the Start Search above the Windows Orb button then press Enter key on your keyboard. And the Registry Editor window will appear. 3. Click on the plus sign (+) or the arrow sign (>) besides HKEY_LOCAL_MACHINE. 4. Click on the plus sign (+) or the arrow sign (>) besides SOFTWARE. 5. Click on the plus sign (+) or the arrow sign (>) besides Microsoft. 6. Click on the plus sign (+) or the arrow sign (>) besides Windows. 7. Click on the plus sign (+) or the arrow sign (>) besides CurrentVersion. 8. Click on the plus sign (+) or the arrow sign (>) besides Explorer. 9. Click on the Shell Folders. 10. Look for the Common Appdata entry on the right panel. If there’s a Common Appdata entry on the list: - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. If there’s no Common Appdata entry on the list: - Right click on an empty space and options will appear. - Click on New and options will appear. - Click on the String Value option. - Set the name to Common Appdata. - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. 11. Close the Registry Editor window. 12. Restart the computer for the changes to take effect. After doing the suggested solutions, you should now be able to update the program successfully.
Posted on May 01, 2009
Need help updateing internet security
Hi, you can get a genuine one from McAfee Product Key , every softwares are genuine and very cheap from it, the importantly, the software works smoothly.
Aug 02, 2013 | Mcafee 2009 Internet Security - 3 User...
Remove security parameters
If your computer is connected to a network or the Internet, it is advisable to use computer security tools, such as a firewall, to protect your computer from unauthorized access or viruses. Windows operating systems come with a built-in firewall, malware protection and Internet security. These settings are automatically configured to the factory's default settings when you purchase the operating system. To alter the settings for these security features, access the Windows Security utility through your system's Control Panel.
Open the "Windows Security" utility by opening your "Start" menu and selecting the "Control Panel" option on the right-hand side. Windows XP users can click on the "Security Center" link in this window. For Vista users, click on the "Security" option, and then click on "Windows Security Center." Click on the "Windows Firewall" option to change the settings for your firewall, if you are using XP. You can turn the firewall on or off, and also configure which programs are allowed through the firewall. Vista users should click on the "Windows Firewall" link in the left window pane and click on the "Change settings" link. In this window, you can block programs from passing through your firewall and grant access to new programs. Click the "Internet Options" selection to configure your Internet security settings. You can raise or lower the security level for different zones using preset configurations, or you can create a custom security level. You can also reset the Internet security level to its default settings. Click on "Automatic Updating" in the Windows Security Center to configure your system's update settings. In Vista operating systems, click on "Windows Update" and "Change Settings." You can configure your update settings to automatically check for updates daily or weekly. You can also set a convenient time for your system to update to prevent interruption. Automatic updating can be turned off by selecting the corresponding option toward the bottom of the window. Select the "Malware Protection" option to edit malware settings if you are using Vista. This option is not available in XP's version of Windows Security Center. You can turn the malware protection programs on or off using the arrow to the right of the "Malware Protection" bar. Click the "X" button to exit Windows Security Settings.
Feb 10, 2013 | HP Computers & Internet
Can Dragon 10 be installed on Windows 7, 64 Bit?
Apparently you need update 10.1 to work on a 64 bit system. Check this out: http://community.nuance.com/blogs/dragon/archive/2009/03/25/dragon-preferred-and-standard-10-1-updates-for-vista-64-available-in-english.aspx
Feb 03, 2013 | NRS Nuance Dragon Naturally Speaking 10...
"Project1 has stopped working"
The issue definitely is associated with Norton. I have Norton Internet 2009. To get rid of the error, the following needs to be done.
* Right Click on the Norton Protection Center Icon from the system tray
* Select Norton Internet Security
* Click Settings
* Under Basic Security, click Auto-Protect
* Click Configure
* Under Real-Time Protection, take the checkmark off "Turn on scanning for Micorsoft Office documents"
Jul 29, 2009 | Microsoft Windows Vista Home Premium with...
I'm unable to start Trend Micro 2009- it was working not Vista cannot find the path
Uninstall first your trend micro then reinstall it again. Most likely you may have gotten a corruption on the software itself.
May 23, 2009 | Trend Micro Internet Security Pro 2009 for...
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Nov 03, 2008 | Computers & Internet
Internet security
1. make sure that the previous installation is inactive
2. since this is a new computer, upgrade to the Trend Micro Internet Security 2009 version. use the same serial number and remember to create a NEW account when prompted.
here's the link:
http://esupport.trendmicro.com/Pages/Where-can-I-download-the-installer-file-for-my-Trend-Micro-Consumer-pr.aspx
Jul 27, 2008 | Trend Micro PC-cillin Internet Security...
2008 Trend Micro Internet Security not compatable to Windows Vista SP1 and Windows XP SP3.
I suggest you to use NORTON 360. this product is so cool.
enhanced antivirus
online fraud protection
automated storage and retrieval
clean up and defragmentation
just like a all in one package from symantec.
i can help you with this product if you have problems
Jan 28, 2008 | Trend Micro PC-cillin Internet Security...
Computers & Internet Logo
448 people viewed this question
David Payne
David Payne
