Question about Samsung SMH7178STD Microwave Oven
Samsung s mw8123st displays se. nothing works
Maytag model MMV4203 display shows SE
same thing as Samsung - shorted key - google manual
Feb 01, 2016 | Maytag MMV4203D Microwave Oven
Why does screen say SE
SE = Sensor Error, its reported that it could be components bent over, and touching each other on the PCB behind the keypad.
You need to be a fair bit mechanically savvy to attempt a repair, and remember to Unplug it before you do! :-)
Sep 04, 2014 | Samsung Microwave Ovens
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
Display shows "=SE-", and do nothing
"SE" means = sensor error, try to dry it out with a hair dryer, if not working, you have to replace the sensor
Jul 29, 2012 | Samsung SMH9151 Microwave Oven
Display show SE from samsung microwave range hood
The keypad has a short in the membrane, which means the keypad control board will probably need to be replaced.
May 05, 2012 | Samsung SMH8165STE Microwave Oven
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
Fan not working on microwave model smh915
Samsung SMH9151W microwave display shows "-SE-", after power on. Nothing else working. Any idea? Thanks a lot
Aug 03, 2010 | Samsung Microwave Ovens
It displays SE and nothing works.
SE error means you have a shorted membrane keypad.
With your model number I can detail your options.
Jul 02, 2010 | Samsung SMH7178STD Microwave Oven
Samsung Microwave Oven shows -SE- on the display. Why?
-SE- error means you have a shorting membrane keypad.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Samsung-authorized service center here or call Samsung's Service Division at 800-932-3837.
Jun 14, 2009 | Samsung Microwave Ovens
Microwave Ovens Logo
67 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
