Question about Fagor 5HA-196 X Single Oven
Fagor 5H-830 X - Fagor 5HA-196 X Single Oven
How to clean inbetween glass on oven door.fagor double oven
take door off the hinges and then unscrew the 2 halves open, wash glass dry really well and reassemble . if you do not get dry it can cause the glass to break when it gets HOT
Mar 19, 2016 | Fagor Ovens
Even with oven off the thermometer light stays on. What could be the reason?
Sounds like the thermostat control is faulty, the usual solution is to replace oven thermostat.
Jan 10, 2015 | Fagor Ovens
How do i clean between glass doors on bottom oven of fagor fb1982x4 ?
disassemble door , clean glass , reassemble. door.
Jul 27, 2014 | Fagor Ovens
Where to find replacement elements. have found several sites in u.k. but are voltages compatible with u.s. versions?
Hi firstly, U.K uses 110 Vdc and rest of the world or most of the other parts of the world use 220-230 Vdc, so unless your Fagor 5HA200LX Oven has a built in voltage converter from 110 Vdc to 220 Vdc, which most new appliances have these days.
Try these shops:
http://www.fagoramerica.com/shop2/replacement_parts/halogen_oven#
http://www.guaranteedparts.com/category/FAGOR.html
Apr 29, 2014 | Fagor 5HA200LX Oven
Setting clock on fagor 6h-230 x
Fagor appear to be a poor quality brand of oven. I also cannot get the timer to turn on the oven. I am going to find out how to bypass it as I dont want to wasre more money on such bad quality machinery. T P Kennedy
Mar 30, 2014 | Fagor Ovens
I have a Fagor 5H 196X oven and whenever I set the automatic timer it cuts off after 3 seconds and the automatic shut down symbol appears does anyone have any ideas
Please find here our reply from the customer service of Fagor America:
This problem could be confusion over how to properly program an automatic cooking function. First, you must program the cooking duration, then you must program the time of day you want the food to be ready. Sometimes customers think they need to program a “start time” and an “end time” versus a “duration” and an “end time”. Please, make sure you are doing both steps correctly. Also, you should be aware that this clock works on the 24-hour principle (military time). I know that sometimes this confuses people as well. If both of those are okay, then it probably has a defective clock. If that is the case, please feel free to call our customer service:
UNITED STATES OF AMERICA and WESTERN CANADA: Please contact ADCO Customer Care at 1.877.743.2467, or by email at: fagor@adcoservice.com
EASTERN CANADA: Ontario, Quebec. Please contact A.G.I Service Inc: Telephone: 450-963-1303 or by email at: nruel@agintl.qc.ca.
If you have any other questions do not hesitate to contact us at: infoappliances@fagoramerica.com
Best Regards,
Aug 22, 2010 | Fagor 5HA-196 X Single Oven
Fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Dec 15, 2009 | Fagor 5HA-196 X Single Oven
Fagor overn doesn't heat
I had a similar problem - turned out the knob on the left by the clock was set to automatic instead of manual.
Dec 15, 2007 | Fagor 5HA-196 X Single Oven
Fagor 5HA-196 X Single Oven Logo
Top Fagor Ovens Experts
Craig Butler
Craig Butler
Bill Boyd
JonSnell Electronic
JonSnell Electronic
Are you a Fagor Oven Expert? Answer questions, earn points and help others
