Question about HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard P/N: 417035-0...
Hannstar J MV4 94v-o 080
Video chip
Hannstar k mv-4 motherboard low performance
The cpu is very cheaply made.For roughly $47 for the cpu don't expect much.You don't have much cache if this is the chip you have.To run programs faster it would need more.Some software needs more cpu power to run better and more cache to run faster.
Hope the link helps.
Level 1 cache size ? 2 x 32 KB 4-way set associative instruction caches
2 x 24 KB 6-way set associative data caches Level 2 cache size ? 2 x 512 KB 8-way set associative caches
Intel Atom N2800 DF8064101050503
Aug 14, 2015 | Hannstar Computers & Internet
Hannstar com
If you press del or f12 when your starting up you shoulf boot into your computer bios and find out what the bios number and the version is from there. there are various ways to get into bios and you can probably google your particular computer but it usually says something onscreen during the boot about setup and then you usually press f1 f2 del f10 or sometimes f12 to get into the bios for info.Be carefull what you change in there and read the instructions carefully.
Aug 24, 2014 | Computers & Internet
Need to know what motherboard is in a toshiba satellite p505d s8007
It's designed by Toshiba but manufactured by HannStar the part number for the motherboard is DA0TZ2MB8X0 (where "X" is the revision code) you will need to disassemble your laptop to see which revision you need, it can be A,B,C...), so far i have seen up to revision "D"
The bios chip is located close to the center in the top section of the motherboard and there is a "U1" mark close to the chip, the chip manufacturer is Windbond part number is 25X80VSIG.
Nov 12, 2011 | Toshiba Satellite P505D-S8007 Laptop
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
Im trying to find out what RAM chips are compatible with my laptop. Its an Acer Aspire 5553G. The motherboard has 'Hannstar J MV-4 94V-0' written on it. Right now there's two Kingston RAM chips in it. I...
BIg thing is to make sure that you do not install memory chips larger than what is recommended. Having said that, not all memory is created equal. Some will work, some will not. It is sort of a cr--shoot. Just got 8 gigs and two of the chips would not work on one of my machines but worked fine on another! So if you want to be positively sure it works, stick with the brand mentioned by the device manufacturer.
Aug 25, 2017 | Computers & Internet
My laptop hp pavilion dv2701tx has no display .there is only blue screen.it's out of warranty and service center told to replace motherboard as they don't repair it.i want to get it repaired. kindly tell...
Hey, cost may vary from the hardware parts. I cannot provide any estimated cost. You can directly contact the HP retailer in banglore. They will proivde you all the details. Hewlett-Packard India Sales Pvt. Ltd. 24, Salarpuria Arena Building
Adugodi, Hosur Road
Bangalore - 560 030 s.gif Phone: (080) 2563 3555 Fax: (080) 2563 3222 s.gif 9:00 AM - 6:00 PM, Monday - Friday (IST)
Thanks
Nnags.
Mar 07, 2010 | Computers & Internet
Need bios update for Hannstar J MV-4 94V-0
I am sorry to say but, I think  your prombelm is that the cpu is the wrong size if you want it to run at that pro speed youneed to get a dual core instead a single core and update the bios then lala linda I hope this helps
Dec 23, 2009 | Computers & Internet
Aderss of acer service center in banglore
2A, Aisa Glenridge 32, Langford Road
Museum Road, Bangalore, Karnataka 560025
080 41526018
#2A, Aisa Glenridge 32, Langford Road
080 41526018080 41526019080 41526020080 22296068 - Fax
Mar 20, 2009 | Acer Extensa 5420-5687 Notebook
No access to DOS screen setup
Not exactly familiar with this particular monitor, but.. Once inside the computer BIOS (cmos screens), press either the external reset (autosync) button or from within the onscreen display. This should resize the screen (it does on any other model I've ever sold). Same solution for SAFE mode. Hannstar does not provide user support either by online or telephone. They rely on the distribution channel to provide support (namely, your reseller). The closest thing to direct HannStar support is here: http://www.hannstar.com/frontend_e/contact/MailProcessForm.jsp?type=10 ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Hannstar AH-191D Monitor
HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  P/N: 417035-0... Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
