Question about Alpine MRV-F345 Car Audio Amplifier
Error code on alpine mrd 500
Hi i need help amp just gives a code of e 3 is that a reset job i can do myself or does it mean spending more money thanks jay
  • 432 Answers
It's a current overflow in the system. You can also get this message if the voltage is too low. Also it can mean a short in the speaker cable. E3 Error is a general error "eccessive current overflow". Check the fuses, I believe there are 4 in this unit but not sure. Check your crossovers. I hope this helps you out. Is this a new hookup or did you buy anything new or change anything?
Posted on Jul 06, 2007
SOURCE:
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
Broken alpine amp terminals
THAT USEUALLY MEANS UR AMP IS WAY 2 POWERFUL FOR UR SUBS
Feb 10, 2010 | Alpine MRD-M501 Car Audio Amplifier
Alpine MRD-M500 Amplifier
That is a code to inform you of an issue, and to help direct you to a particular area of concern
HOT & E-1 = both for heat issue
E-2 = for a voltage issue
E-3 = for a current issue.
While yours is a current issue, that reflects a problem with your input or output signal pairs. You should disconnect the subs at the amp, then operate the unit as normal to see if the code reappears. This is the start of your process of elimination, where as you will be able to determine the general location of the issue, weather it is before - internal - after the amp, hence If after the subs were disconnected, the code did not return then it would be obvious that you should focus on the subs and their signal pairs. troubleshooting in small increments until the issue is discovered.
Hope this helps...Good luck
Aduz
Mar 27, 2009 | Alpine MRD-M500 Car Audio Amplifier
Need help!!!!!!!!!!!!!
ALPINE ELECTRONICS OF AMERICA, INC.
19145 Gramercy Place, Torrance,
California 90501, U.S.A.
Phone 1-800-ALPINE-1 (1-800-257-4631)
Mar 16, 2009 | Alpine MRD-M500 Car Audio Amplifier
How to unlock my alpine mono power amplifier mrd m500?
Hi. If you shorted (touched) the speaker wires together, or let them touch the chassis of the car, then it may have locked out. Just turning the amp off and back on will fix this, so it sounds like you have done damage to it. Most amps have a speaker relay which gives a click sound when you turn on. If there is no click, then it may have a power supply failure.
Mark
Oct 24, 2008 | Alpine MRD-M501 Car Audio Amplifier
Alpine mono power mrd m500 amp
Try switching the lowpass filter down to 80hz or lower, then adjust the bass boost to your liking.
Jun 28, 2008 | Car Audio & Video
Alpine amp mrd-m605
The amplifier probably has shorted output transistors. If the amp gives the same error message with the speaker wires disconnected from the amp, the amp needs to be repaired.
Dec 30, 2007 | Alpine MRD-M605 Car Audio Amplifier
Alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
Error codes
One of the parts went bad, and you need to take it into the dealer. The way Alpine's error codes work are very vague. E-3 could mean the psu fried, a resistor went bad etc.
Aug 12, 2006 | Alpine MRD-M501 Car Audio Amplifier
Alpine MRV-F345 Car Audio Amplifier Logo
595 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
