Question about Remington Electric Pole Saw
Used my saw on one limb and it quit
I cut one limb about 2 inch in diameter and did not get it into a bind but now it does nothing. Was this a common problem because I see a lot of them for sale as reconditioned. ( 10 inch electric pole saw) What can I do to get it fixed since the place I bought it is out of business. Thanks John M.
  • 188 Answers
SOURCE: Craftsman 16 inch cain saw sprocket wont turn
Sounds like the sprocket could be stripped. If so, then you would need to replace the sproket. I suggest you contact Master Parts at 800-466-1446 or online at www.masterparts.net. They may be able to help you.
Posted on Jul 01, 2009
  • 188 Answers
SOURCE: Our new Pole Saw, (6 mo old, used 2 times) just
Check in the handle, the wire connection to the electrical switch could have came loose or disconnected. The switch may need to be replaced. Maybe part of the cord went bad, but I would think that would be less likely, but possible if you had a electrical surge.
If the wire connection is okay, then I suggest you try to purchase a new switch part # 077525S, that may do the trick. You can by one by calling Master Distributors at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps!
Posted on Jul 10, 2009
  • 4088 Answers
SOURCE: It just quit. Model 111409-01 6" electric pole saw..remington
Parts for these machines are not being manufactured any more as the company has ceased operations. Search the internet for companies that advertise these parts--you may get lucky! On the motor--check the brushes as they seem to fail often. Good luck!
Posted on May 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: Just given a 10" Electric
What is the model# please?
Thanks!!
Posted on Aug 08, 2010
  • 193 Answers
SOURCE: what's the best way to use my 16 in electric saw
This is somewhat subjective. Eveybody does it a little different.If you are cutting limbs from a tree, start an undercut about where you want the limb to fall free of the tree. Use the upper edge of the chain to cut it about a fourth of the way through. Then start from the top of the limb over where you made the undercut.
Posted on Sep 25, 2010
How do I find a drive gear for a wen electric limb trimmer model 6110.
Have you tried WWW.wenproducts.com yet? I ask because they sell parts to their products there.
If this is like some of the other branded electric chainsaw type pole saws the same small gear is used on many electric scooters and that is available on many scooter part sites.
I tried to get a look at the wen limb trimmer but did not find pics. If you add an image I can give you better info.
Oct 26, 2014 | Garden
How can you buy just the saw for the 8" 2 in 1 pole saw.
after looking at reviews written on
http://www.chainsawsdirect.com/Earthwise-CVPS41008-Chain-Saw/p7224.html
Robert
Tried chain saw. Working on limbs about 12 ft above ground.
First limb about 3 inches diameter, Oak. Worked fine.
Second limb same size. Cutter slip off branch could not stop the saw from hitting ground. Broke case where it attaches to pole.
No parts, and no way to repair it as company had no idea what kind of cement/glue I could use. So one branch cost me $120.00.
Sent To Customer Service
Shawn
Like Robert my saw hit the ground and busted in the same spot (this will happen to you sooner or later) and you can not get repair parts, its now a door stop.
Pros: Easy To Use, Light Weight
Cons: Can Not Get Repair Parts
I am guessing you mean the entire cutting end of the saw too, I would get a new one either same model so you have a spare pole or find a another brand that definatly sells spare parts.
Ive never used a electric polesaw but have done alot of work with with longer petrol and shorter hydrolic polesaws, even top of the range they can be broken easily always keep the chain sharp, cut one branch at a time or small clumps on a hedge.
Commonly they get dropped cause they get really heavy extended a shoulder belt helps alot as do coffee breaks.
Or they get jammed in the branch being cut which can be really dangerous with a half cut branch, be ready to run.
Also never use from a ladder
Jul 07, 2014 | Earthwise CVPS41008 - 8" 6.5-Amp Electric...
New skil HD5510-01 5 1/2 inch trim saw quit running after cutting a bunch of 2x4s
Does it have any sort of blade safety lock?
Did the blade bind and possibly throw the built in circuit breaker?
If so, there may be a small pin or button you press.
Did you try a different electrical outlet?
The one you were using could have a GFP and not able to take the draw of a saw.
Jun 25, 2011 | Skil Saws
Saw works but stops when I begin cutting a limb. Model # 104316-04 Thank you in advance. Joe Alcamo
Hi, make sure the chain is not on too tight, It should lift from the bar about a quarter inch. Also if there is a chain brake make sure that it is disengaged. If the chain stops but the saw is revving high then there may be a worn out clutch that needs to be replaced. Finally make sure the limb that you are cutting is not binding the chain under its' own weight.
Nov 16, 2010 | Remington Electric Pole Saw
What's the best way to use my 16 in electric saw to cut off tree limbs?
Sep 25, 2010 | Remington 16" Electric Chain Saw
Mcculloch EM250-14 RPM Slowed suddenly
The chain must be properly sharpened to cut efficiently and the oil pump must be feeding oil to the chain/bar. Check the oiling by running the saw with the bar tip near some cardboard for a few moments--it should throw off a thin line of oil on to the cardboard. If not, remove the bar and chain and run the motor for a few moments--it should ooze oil out of a side port that exits near the drive end of the bar. If still nothing, check the oil tank filter for plugging, then the oil pump itself--it may have a plastic gear that has stripped it's teeth. Once you get oil from the side port, clean the oil passages in the drive end of the bar, and reinstall the bar and chain. Hope this helps!
May 26, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
When i use the electric saw and put a load on the chain it stops
The problem you have isnt adequately explained.
  1. You may be tripping a thermal overload.
  2. The chain may be to agressive and overpower the motor.
  3. The chain may be excessively tight, that combined with the load may be the cause.
  4. Limbs as the cut progresses, pinch the bar and chain.
  5. No bar oil or defective oiler.
  6. If equipped with a clutch it may be slipping.
There are other causal factors too. Read your manual, limbs require 2 cuts, the first from the bottom about ½ way through, then offset a couple of inches toward the trunk from the top . HTH
Lou
Sep 24, 2009 | Remington Polesaw Wizard
Jun 09, 2009 | Remington Electric Chain Saw
Straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Remington Electric Pole Saw Logo
66 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
