Question about Stealth Cam The Unit 8.0 Megapixel Infrared Digit - STC-U840IR
Pictures taken at night appear white - Stealth Cam The Unit 8.0 Megapixel Infrared Digit - STC-U840IR
My canon A-460 powershot
make sure it is not in Night mode.
Jul 26, 2010 | Canon PowerShot A460 Digital Camera
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Oct 06, 2009 | Fujitsu Cameras
My daykight pictures are all white and hazy. What
If the pictures look normal while taking them, but become white after they have been taken and if they have horizontal stripes on them (zoom in the pictures to check it) then it's a broken shutter cable or stuck shutter blades. If they appear white before the picture has been taken, then it's a CCD problem. They are hardware problems, not software, so I'm afraid you will have to give it away for a repair. You should contact your local Canon service center. I must warn you that all these problems are considered hard to repair, so it could get expensive.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot SD1000 Digital Camera
White screen appear of pictures taken
CCD FAILURE !
Call Canon for FREE REPAIRS it is a known issue ask them about BAD CCD see this link for service advisory
RATE ME WELL !
Regards
Zohail
Jun 01, 2009 | Canon PowerShot A460 Digital Camera
So much light on picture
Hi, Mark here see if I can help.
Sound like your camera is set to night photography.
Try resetting it to Auto or sports when shooting in daylight.
Hope this fixed ya! need more help comment back.
Please rate. Good Luck!
Mar 28, 2009 | Canon PowerShot A450 Digital Camera
Outside pictures turn white
Check the white balance. This should be under menu. When you are outside in sunlight, change is to the sun icon, ect.
Are the exposures very long? If they are, they need to be shorter in high light, and longer in lowlight situations.
Jun 20, 2008 | Samsung Digimax D53 Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
Stealth Cam The Unit 8.0 Megapixel Infrared Digit - STC-U840IR Logo
18 people viewed this question
Top Stealth Cam Home Security Experts
Lawrence Oravetz
Are you a Stealth Cam Home Security Expert? Answer questions, earn points and help others
