Question about HP PSC 2355 All-In-One InkJet Printer
Im getting an error code of 0x8810869c on my Hp psc 2355 printer
SOURCE: I get an error messege (carrige jam)
I have found that when I slide back the carriage to the left by hand and expose the bottom right hand side, there has been an accumulation of ink that is preventing a part from sliding from front to back. Inspect the bottom right hand side where the black and color cartridges normally sit. You will find a flat sliding piece directly beneath the position where the cartridges normally sit, that will not slide forward to the front of the printer and back towards the back of the printer easily because of the ink that has accumulated and is causing a drag. I used q-tip swabs and some alcohol and cleaned out the rails that the piece slides in. Use a flashlight to inspect. After cleaning it appears that it is printing normally again. Repeat the process as needed. Bob in NC
Posted on Jan 28, 2009
Sandy4u
  • 107 Answers
SOURCE: Installation of HP PSC 2355 Problem
Hi ,
if u want prosiger for installation of psc 2355 please follow the steps
  • frist u remove printer usb cable from CPU
  • uninstall all drivers & software of printer withc u try ...
  • insert installation cd in rom
  • start installation & follow the steps .
  • it will get massage looking for new hardware or please connect u r printer
  • please connect u r printer in online
  • make sure u r printer is power on before u connecting to u r CPU
  • it will get recocnised u r printer follow the instructions
  • get finish installation.
check in printers it will be install or not ...
if this information is useful for u please Rate me.............
Posted on Jun 18, 2008
adonscott
  • 106 Answers
SOURCE: error response on hp psc 2355 AllinOne printer,scanner, copier
Issue The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, please let me know.
Thank you so much. I Remain
adonscott
HP TECH
Posted on Jul 04, 2008
bschilz
  • 2049 Answers
SOURCE: HP PSC 2355 printer gives
Disconnect the printer from the computer remove loaded paper, turn it off & disconnect it from AC for at least 30 mins.That should resove your problem.
Posted on Oct 01, 2009
  • 123 Answers
SOURCE: Have HP PSC 2355 and receive error 0xb900005 what
It means there is an interal error and the printer has to be reset.
The best solution is to unistall the printer and then reinstall.
1.Unplug the printer from the computer not the cord just the cable.
2. Do the unistalling process. Whhen done do the following to the printer before connectiong back the printer.
Take out the cartridge then wait for the message Insert ink to display and unplug the cord. Wait 60 seconds.
Plug in the cord and when the printer restarted insert the cartridge.
Close the cover. If promted to print a calibration page report printed it.
Reconnect the cable.
Your printer should be running good now.
Posted on Jul 16, 2010
Can I use an HP75 tri-color printer cartridge in my HP PSC 2355 All in one printer even though it usually takes the HP95?
HP 75 tricolor cartridge is not designed for PSC 2355.If you try to install it,you'll get a message incompatible ink cartridge or cartridge problem.using a different cartridge may also damage the chip embedded in the printer.do not use hp 75 as a replacement for hp 95.
Jun 19, 2011 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 printer gives "Memory trashed?" error
Oct 01, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 Printer not working
reinstall your system right now... or reformat the windows
Jun 17, 2009 | HP Hewlett Packard LaserJet 5200 Printer
Run as error on dell
go to control pane/ user accounts/ user accounts/ look at your acct (make sure its says admin and not limited) if limited change it to admin. reinstall software, you should be on way now.
good luck
Jun 07, 2009 | HP PSC 2355 All-In-One InkJet Printer
Error:0xb9000027
with my pc hooked up to the printer i get error
codes on it it is a psc 2355v all in one
May 12, 2009 | HP PSC 2355 All-In-One InkJet Printer
My HP PSC 2355 is getting the Error:0x88053674, which sounds like an address error
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP PSC 2355 All-In-One InkJet Printer
Hi ,
Jun 18, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
172 people viewed this question
Seeker5211
Seeker5211
