Question about Restoration Hardware Allaire Desk Fan Black
Cleaning the fan
How do you open it to clean it?
I need to open my fan/heater to clean it but there are no screws to take out. How do I open this so I can clean it. It has a lot of dust.
Some unit may have snap on covers and no screws. Some you can twist and take cover off. Some may have little taps that covers both front and back covers, just pull taps up.
Sep 11, 2014 | Refrigerators
Cleaning Fan
Tower fans- Clean your fan by using the brush attachment on your vacuum cleaner to vacuum the intake grills to remove lint and dirt. For safety purposes, never open these units for any reason.
Jun 12, 2013 | Dryers
How to open to clean cooling fan
Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it. You also might want to get a laptop cooler.
Jun 30, 2012 | Toshiba Satellite Computers & Internet
Icannot open fan to clean.
If your tower fan is like mine then in the handle there are two screws holding on the back just remove those and it comes apart.
May 30, 2012 | Dryers
I cannot open to clean
There are two screws in the handle remove them and the back panel comes off if they are tower fans
May 30, 2012 | Lasko 2517 Tower Fan
How do I clean the Lakewood Tower Fan LWTF-42/RC-DLX. How can I open it to clean the blades
Open the grills and use a long stem tipped with cloth dipped in kerosene to lightly clean the dust. Then use a similar arrangement of dry cloth wound on it to wipe clean the moist dirt. Repeat the process and you will have a clean blade. Use a jet air blower to assist you , use face mask and do it out in the open.
Helpful ?
Aug 20, 2010 | Lakewood 007 Floor / Box Fan
Need cleaning, not good output
OPEN THE INNER AND GET THE FAN ND CLEAN IT
Jul 10, 2009 | Lasko Stanley High Velocity Blower Fan...
Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Jul 03, 2009 | Vornado Circulating Fan
Cleaning Honeywell table fan
By the way please check my video on YouTube for your answer. Watch, Subcribe, Share, and Comment!
Thank you
" How to Open a Honeywell Fan to Clean" on YouTube
Jun 14, 2009 | Honeywell HT-800 Table Fan
Opening fan
first open your cpu cover carefully ,by opening the screws once your cpu cover is opened then carefully remove the wire of the fan connected to the motherboad then open the screws of the fan and clean it then do the same just connect your fan to the motherboad and screw it up and its over make sure that your fan is working and its over
Nov 10, 2007 | WeatherWorks CH-V18 Floor / Box Fan
Restoration Hardware Allaire Desk Fan Black Logo
Top Restoration Hardware Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Restoration Hardware Furniture Expert? Answer questions, earn points and help others
