Question about Mitsubishi LT-46151 46 in. HDTV LCD TV
Screen blue blinking green light
Lost power during night now tv doesnot work
SirHanz
  • 145 Answers
SOURCE: Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Posted on Feb 12, 2008
SOURCE: Tv won't come on. It has a flashing green light on by the power button.
the tv is not come on.it has a flashing green light on.tv model hd 1080.
Posted on Oct 22, 2008
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
SOURCE: green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Posted on Jan 17, 2009
rylee_smith
  • 8619 Answers
SOURCE: can't get power to TV. The green light continues
Hi
Thanks for using FixYa. The green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating with each other. This issue is due to 1000uF/16 volt power supply capacitors in the "DM module" (one of the two onboard microprocessors). These capacitors are apparently small as compared to load they get & due to this they will eventually fail (usually after about 3 years). Or else they fail when there are voltage fluctuations in the circuit above 16 volts. It is recommended to install either 1000uF/25 volt or 1000uF/35 volt capacitors as replacements, so that they will be more than ample to handle any voltage spikes that will occur. To do the repair you’ll need to take the back off the TV apart in order to remove the faulty DM module and need to desolder the old capacitors on DM board and install. Also check the grounding straps which are essential to the proper functioning of the DM module. All this is only recommended to be done by someone who has electrical expertise and know how to solder/re-solder components else contact a qualified repair tech and let them know what the exact issue is with your TV. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 11, 2010
Red and green lights blink but why is there nothing on screen?
The voltage from the power adapter is critical for proper operation. If it's a little low, the lights will work, but not the picture. There are capacitors on the motherboard that fail with age, so check them too.
Dec 08, 2011 | Swann Communications DVR4-Alert Video...
Green status light FAST blinking and does not shut-off.
SORRY, NO ANSWER.>>> AFTER TURNING MINE OFF FOR THE NIGHT THEN BACK ON IN THE AM, STUCK ON THE WELCOME BLUE SCREEN W/BLINKING GREEN LIGHT BESIDE THE POWER BUTTON. TRIED HOLDING DOWN THE POWER BUTTON FOR 10 SEC., BUT ALL IT DOES IS SHUT OFF. I CAN NOT GET IT TO PERFORM SYSTEM RESET. PLEASE HELP, IF YOU FOUND A FIX FOR YOURS. THANKS! please EMAIL ME AT scottsphoto2@aol.com
Nov 17, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Mitsubishi LT-46151 46 in. HDTV LCD TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
