Question about Cobra Radio Communications
Cobra 25 lx special edition rf power output fail
No sound
    Genius:
  • Cobra Master
  • 1,795 Answers
Try it with a different antenna. make sure your swr is low
Posted on Nov 25, 2014
wyoed1
  • 211 Answers
SOURCE: No sound
The Cobra 25 requires the mic to be working for any sound to come out. My suggestion is that you first try a new mic. If this doesn't work, look real close at the board on the soldered side ( around the if section, thats the area that right under the waxed area on the component side of the board ) for cold solder joints ( broken lead solder) You may need a magnifing glass. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
One Wire
  • 126 Answers
SOURCE: Cobra 25 LTD Classic
turn your squelch all the way counter clockwise and your rf gain clockwise. If that doesn't help, try hooking up an external speaker to make sure its not the internal speaker. If these help or don't help, please reply on this thread to let us know, so we can give you more advice if needed.
Dean
Rollin CBs
Posted on Jan 26, 2008
most cbs have the same power cod
Posted on Aug 14, 2008
Benimur
  • 6966 Answers
SOURCE: new power chip
To my knowledge on a Cobra 29 board, replacing TR14 (2SC2029) with a 2SC1969 is supposed to improve/increase the TX power output. Additionally however, L12, 13 & 14 must also be adjusted while the 29 is hooked up to a dummy load/watt meter. Should you wish to try for experimental purposes only:
  • Modulation improvement - adjust VR4 to desired level or cut D11or max talkpower remove TR18 .
  • replace TR14 with 2SC1307 (or 2SC1969).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 06, 2008
Communicomm
  • 90 Answers
SOURCE: Cobra 200gtl High Power Transmit problem??
Depending on the type of power supply, radio frequency (RF) energy from the transmitter may be 'fooling" it into thinking that you're overloading it. Check to see if there's any discernible dimming of the meter lamp when this problem occurs, if so, the supply is the culprit.
Otherwise, its probable that the final amplifier transistors are overheating, either they are 'leaky' or not properly attached to the heat sink.
Posted on Sep 26, 2008
Factory frequency channel for a cobra 25 lx lcd cb
27mhz look in your owners manual and there should be a page with all the channel frequencies
Sep 02, 2014 | Radio Communications
My cobra 29 lx is saying that my rf gain power failed why is that
you may have burnt the diode that a variable controls or you messed with it and burnt it out.
Jan 21, 2014 | Cobra 29 Lx Full-featured Cb Radio
Radiocheck shows rf output power failure
its an inside the radio fix mine is doing the same thing and I have had the time to get into it and fix it.
Jan 01, 2014 | Cobra 29 LX 40-Channel CB Radio with...
Cobra 29 lx chr le rf power output fail
no it didn't fail. the radio is designed not to except any mods without bypassing something . If you don't know what to bypass then leave it alone and turn it back to where it was.
Feb 26, 2013 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
I just installed a new 25 lx in my rig, a Freightliner Cascadia. It's automatic test says that the battery voltage is good, but the RF out put is failing. The truck came standard with twin fibergl
It sounds like an antenna or coax problem. Twin antennas are a pain to balance and not worth the effort to install. All twin antennas do is make the antenna manufacturer richer. If the antennas use PL259s that screw into the bottom then they are nothing but water and corrosion traps. You must make sure all connections are clean and tight and waterproofed. I use an MFJ antenna analyzer to check the antennas for all my customers. It can tell you very fast if you have a problem. Any good CB shop will have one. I never trust the cheap SWR watt meters but actually the built in SWR meters on the Cobra radios are not bad indicators. I trust them much more than most external meters. Hope this help at least some. Just use your head and remember that your radio signal needs a good clean and clear unbroken path.
Jul 16, 2012 | Cobra 25 Lx Lx Platform Cb Radio With...
Radio Communications Logo
61 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
