Question about Cuisinart EM-200 Espresso Machine
Cuisinart EM 200
Thanks for the help on the espresso machine. I tried running just water through, and the flow was fine with just water. Switch to grounds (especially pods) and it's horrible. I'm going to try decalcifying tonight, perhaps that will do it?
  • 8,596 Answers
I was about to abndon pods on this machine, and then I actually used the Pod filter basket - it worked like a charm. Decalcifying is not a bad idea.
Posted on Feb 15, 2009
Espresso not hot enough
CoffeeGeek - Espresso: Espresso Machines, Need help with a ...
coffeegeek.com > Discussions > Espresso > Machines
Feb 1, 2010 - 10 posts - ‎4 authors Well, I'm throwing in the towel...or my Cuisinart EM-200 actually. ... coffee and it's not hot enough to even make me pull my finger out of my flat, ... Espresso Machines, Breville BES840XL Owner ...
Aug 20, 2013
Espresso Machines, Cuisinart EM-200 ...
Nov 14, 2011
More results from coffeegeek.com
Cuisinart EM-200 Espresso Machine Coffee not hot ... - Fixya
www.fixya.com > ... > EM > Cuisinart EM-200 Espresso Machine
Cuisinart EM-200 Espresso Machine, coffee not hot related issues. ... ...to "extra hot" If still not hot enough, try zapping your coffee for a few moments in the ...
Oct 29, 2015 | Cuisinart EM200 Stainless Steel Espresso...
My em 200 cuisinart espresso maker stops brewing and beeps
My em 200 Cuisinart express
maker start and stop and beeps what I do
Jan 14, 2013 | Cuisinart EM-200 Espresso Machine
My Cuisinart EM-100 Espresso Machine leaks water from the bottom.
Thanks Joe received ur gasket in mail installed it in 10 minutes and no more leak! The old was caked up above and below.
Dec 03, 2012 | Cuisinart EM-200 Espresso Machine
Making wear noises, stop and light blink like is not water... HELP
Descale with vinigar 2 to 1 then water.Run the whole tank through it.
Nov 04, 2012 | Cuisinart EM-200 Espresso Machine
Do you know where can i find the rubber gasket that goes around the brew head of my Cuisinart EM 100 espresso machine ?
It sounds to me that your group seal is bad. Since this machine is a 15-Bar unit, it puts out quite a bit of pressure causing water to leak out around the portafilter when making espresso if your seal is old or damaged. The pressure doesn't build up as much when you are running just water through the machine - hence the reason why the machine works ok without grounds. I sell a LOT of parts and accessories for various manufacturers of espresso machines. This particular seal is extremely difficult to locate fom Cuisinart, but is rather easy to replace. Through extensive testing, I have located a replacement gasket produced by another major manufacturer that fits the Cuisinart EM-100 & EM-200 machines perfectly. I sell them for $10.99 each (or two for $19.99) which includes shipping in the continental US and I accept Paypal. If you would like to contact me via email (cowboy_romeo@yahoo.com), I will be happy to help you out.
Mar 20, 2012 | Cuisinart EM100 Stainless Steel Espresso...
Half of the time, espresso leaks (or sprays) out of multiple points on the handle/portafilter, instead of coming out of the two designated holes. Almost as if too much pressure builds so it gets forced out...
Try running water only and see if you get the same result. If you do, then soak the filters and the bottom of the metal basket of the portafilter holder in vinegar (distilled white). In my experience, this unit requires constant cleaning. But the espresso is good.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart EM-200 Espresso Machine
Cuisinart EM 200U expresso machine instructions
Slide water chamber out and put filtered water in it - i would make only 1 cup at a time, so fill only to the minimum fill line. Most tap water will overpower the taste of the espresso. Use grounds, not pods - podded espresso will come out too weak. I would suggest using the double filter cup instead of the single - doubles can be ordered from Cuisinart website.
Here's a link to the manual:
http://www.cuisinart.com/share/man/579_man.pdf
-Tha Mp3 Doctor
Nov 15, 2008 | Cuisinart EM-200 Espresso Machine
No flow
Tamp the coffee a little less - run water through filter basket to make sure it is dripping out before filling with espresso grounds. Dry the filter thoroughly before inserting coffee grounds. I would reccomend using double filter basket only instead of the single.
Aug 11, 2008 | Cuisinart EM-200 Espresso Machine
Cuisinart EM-200 Espresso Machine Logo
621 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
