Question about Vizio E370VL 37 in. LCD HDTV
How to do a factory reset on a vizio e370vl - Vizio E370VL 37 in. LCD HDTV
5 Suggested Answers
protvrepair
  • 153 Answers
SOURCE: busted screen on a vizio e370vl is it fixable
I wasnt able to locate the panel part number. There were 2 different ones used in your set based on the serial number. But I have never ever seen a panel that was cheaper than the purchase price of a new tv. I hate giving out bad news.. Sorry Most places that sell salvage parts for tv's like ShopJimmy.com never have the LCD screens because thats what always is broken making them salvage..
Posted on Oct 19, 2010
  • 5187 Answers
SOURCE: have a vizio e370vl tv
You will be able to connect the DVD recorder to the TV for playing a video. Connect the two devices using the best output available from the DVD recorder (HDMI or component video from the output of the DVD recorder to the video in of the TV). To record programming, if the DVD recorder doesn't have a tuner, you will need a set top box. This can be a satellite receiver, a cable box or a set top tuner depending on the source of your TV signal.
If the DVD recorder has an NTSC tuner, you can use a digital to analog converter as the set top box for OTA signals. Note the d-t-a converters that were available with the government coupon only provided SD signal output. HD digital to analog converters do exist and you will be able to record a HD program as HD. (This does depend on the DVD recorder.)
Depending on your situation, you may want a splitter to connect the signal to both the TV and the DVD recorder and be able to watch one program and record another. With digital OTA signals, an amplifier may be needed to maintain signal strength for the tuners to see the channel. For coax input, you'd put the splitter before the devices. Then feed one line to your set top box and the other to the TV. Then output from the set top box to the DVD recorder. If you have an ATSC (or QAM for unencrypted cable) tuner in the DVD recorder, then you use the same basic arrangement with the splitter without the set top box.
I hope this helps.
Posted on Jan 16, 2011
tekkiinh
  • 59 Answers
SOURCE: vizio e370vl turns on then powers off
This unit has infra red detector for remote. You may be getting IR from another source in the room (eg: bad light bulb or light reflecting off window pane). Also if you use the JAG Wheel on side of set, instead try the remote - the JAG Wheel may be the problem (dirty switch or damaged).
Posted on Oct 04, 2011
  • 6 Answers
SOURCE: Vizio E370VL Gray Screen no buttons work
This sounds like a problem with the main board in the TV. The main board is similar to the motherboard in a computer. You will need a professional to repair/order the parts. I would strongly recommend looking into purchasing a new TV rather than have this one repaired. In most cases the repair for a main board would be within a couple hundred dollars of a new set and often will not last very long.
Posted on Oct 19, 2012
My vizio E370VLE is getting no power at all. The vizio logo under the screen isn't even lit up. I have tried plugging into new outlets and even switch out the power cord with a new one so i know its n
the problem is probably your main power board.. these can be replaced by yourself.. find the model no and then enquire about a replacement board ..I have had similar problem tv repairman wanted $500+ to fix board only cost $134..make sure to disconnect power supply ..undo all the screws around back of case including wall mount and base follow power lead entry into case do not touch any circuitry as some capacitors store power disconnect the little plugs that run from the boardundo the 4 screws and replace with purchased replacement board and re assemble..
Dec 20, 2014 | Vizio Televison & Video
Vizio e370vl turns on i get the white vizeo logo and shut off in 3 seconds what is causing it. i tried new power supply and does same thing.
May need firmware updatebut here are some links that may help
Basic LCD troubleshooting guides
http://www.badcaps.net/forum/showthr...956#post305956
Voltage regulator DO testing
httwww.badcaps.net/forum/showthr...999#post300999
TV factory resetcodes and listing
http://www.badcaps.net/forum/showthread.php?t=24809
You can also call HD Repair at 1-800-713-2671
I hope this helps you..
Dec 18, 2014 | Vizio Televison & Video
What size are the screws for base stand on vizio E370VL
Quickest way is call Vizio with the model number.
Aug 29, 2012 | Vizio E370VL 37 in. LCD HDTV
Vizio VO370M red color has gone away
Change the input to some other device and see. Then if the problem persists, this might need attention by a qualified service technician.
Jul 25, 2012 | Vizio E370VL 37 in. LCD HDTV
37 in vizio tv stays on vizio screen
Main system memory IC might have been damaged. Set need service Contact any experienced service technician; or the authorised service center for Vizio at your town.
May 12, 2012 | Vizio E370VL 37 in. LCD HDTV
Vizio e370vl turns on then powers off
Oct 04, 2011 | Vizio E370VL 37 in. LCD HDTV
Vizio E370VL 37 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
