Question about Garden
John Deere 4650 Powershift Transmission slipping between 1 and 7
Sipping gears doesnt engage
  • 11 Answers
SOURCE: John Deere LT 133. Will not move with mower in gear and clutch/brake released. A smell like hot rubber prior. Mower will engage. Thanks.
It could be that the belt jumped off the pulleys and got caught between a pulley and a belt guide,or the trans-axel seized up ,or brake was stuck while in a high gear,and burned up the belt. most likely the first reason. if it wasn't for the burning rubber smell,I would also look for a broken clutch/brake return spring .The pedal would stay down with a broken spring
Posted on May 24, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
2007 JD 450J 2500 hours: checked oil levels - Hydraulic and transmission. Engaged drive, normal PSI, crawled at very low jerky speed. Backed up some and then it stopped no PSI and no longer moves.
sometimes they have air pockets disengage the transmission
as to push. start put in gear and run this will help burp out air.
shut off and engage the transmission and try.
Dec 12, 2016 | John Deere Garden
John Deere 760-A scraper will not move forward but it will back up.
It is almost like a 4620 powershift farm tractor trans. When reverse goes clutch packs are shot. Sorry about that. Be sure the shift linkage is moving full range top to bottom.
Nov 21, 2016 | John Deere Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
1986 K5 Blazer 4x4 wont move when put in drive or reverse even in 4x4
Hi Don, have you checked the gear box oil level? Regards John
Sep 01, 2012 | Cars & Trucks
Transmission won't engage
sounds like its time for a new mower
Apr 24, 2012 | John Deere Garden
Tractor slips in all gears but rearend doesnt make noise
Sounds like the belt tension pulley is loose or the belt is stretched out
Aug 08, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
The Hydrodrive in my 1642 John Deere slips
Sounds like you have a gear or two chewed up. Sometimes these can be replaced, but with some models they aren't made so you can open them up and replace the gears. You'd have to have a John Deere dealer to tell you which one you have or contact the main company.
Jun 23, 2009 | Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
