Question about Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite a135-s4427 Boot Manager Missing
This Laptop will not even boot to recovery cd at all it just says boot manager missing press ctrl. alt. delete to restart.
Anyone have any ideas, I think its a hard drive problem
  • 6 more comments
  • pappy101 Jan 22, 2009
    I have tried that, it won't let me boot from the cd or the hard drive...
    just the black screen with
    BOOTMGR is missing
    press ctrl alt del to restart
    that does not work either...
    won't boot from cd or hdd
    again, all the computer does when restarting is the black screen...nothing else...the only option it gives me is ctrl alt del
    I have a copy of XP Pro and that does not work either..
    I'm stumped
    again that's all great info. but all I get when booting to cd or hdd is the same screen with NO options
  • pappy101 Jan 23, 2009
    don't have either one at this point, that's why I'm truing to fix it here myself...
    To me it would seem to indicate a problem with the hard drive...The cd drive has intermittently been disappearing also before this final meltdown
    The cd drive was working fine before this happened, but it was disappearing altogether on occasion so I'm not sure what that indicates.
    I don't have an external myself, but a friend of mine does, so that may work...
    the problem with an external drive is that the computer won't have access to it due to the fact that they are all USB drives, is that correct or am I missing something here
  • silient bob Feb 12, 2009
    i have a problem with boot mgr not responding, and showing that isn't there. won't boot up. except in bios
  • 67 Answers
Its not the hard drive my frined, its the boot loader it has been deleted or it has been compressed the only way to fix this is to use the recovery cd you have, to boot from cd-rom you need to go into bios which is usualy F2 or F5 key, then under boot manager or somthing is the primary and secondary boot, change the primary to CD-ROM, then save it and restart then it should boot from cd-rom then you have do a start-up recovery.
Posted on Jan 22, 2009
  • 3 more comments
  • Daniel Davies
    Daniel Davies Jan 22, 2009
    ok, then you need a copy on windows xp or vista, even the upgrade disc will work, and load that cd-rom there is a shortcut key like F key on your laptop which does a multiboot or boot from cd-rom
    try going into safe mode? pressinf F5 or F8 depends on laptop if not try doing the same thing by pressing at the begining F key then click on last known configuration that worked, if you did get into safe mode do a system restore.
  • Daniel Davies
    Find yourself receiving "BOOTMGR is missing, Press Ctrl+Alt+Del to restart" message? Don't stress! Its easier to fix than you think. Here's how:
    SOLUTION 1
    - Get your Vista installation DVD and pop it into your drive.
    - Then restart your computer
    - Set your computer to boot from DVD or CD in your BIOS.
    Vista
    will ask you for language and keyboard layout information, after which
    you will be asked if you want to re-install Vista or repair your
    existing installation.
    Select Repair. After which Vista's System Recovery Tool will start.
    Select Startup Repair and let Vista do its thing! That really is all there is to it!
    If that doesn't work try this:
    SOLUTION 2
    If
    the previous method does not resolve the problem, you can rebuild the
    BCD store by using the Bootrec.exe tool in the Windows Recovery
    Environment. To do this, follow these steps:
    - Then restart your computer.
    - Press a key when you are prompted.
    - Select a language, a time, a currency, and a keyboard or another input method, and then click Next
    - Click Repair your computer
    - Click the operating system that you want to repair, and then click Next
    - In the System Recovery Options dialog box, click Command Prompt
    - Type bootrec /rebuildbcd and then press ENTER
    If Bootrec runs successfully, it will present you with the installation
    path of a Windows directory. To add the entry to the BCD store, type
    Yes . A confirmation message appears that indicates the entry was added
    successfully.
    • If Bootrec cannot locate any missing Windows
    installations, you must remove the BCD store, and then you must
    re-create it. To do this, type the following commands in the order
    shown below: (Remember to press ENTER after each command)
    bcdedit /export C:\BCD_Backup
    ren c:\boot\bcd bcd.old
    bootrec /rebuildbcd
    - Restart the computer.
  • Daniel Davies
    then only one more soluition is to get the warrenty involved in this one, or if you have insurence claim off it.
  • Daniel Davies
    Daniel Davies Jan 23, 2009
    its not the hard drive thats intact, what has happened the boot manager has become corrupt or missing they only normal way to fix it is to use the operating system cd-rom and do a start-up repair, but if your cdrom is failing to read cds, then i can suggest a external cd-rom and try doing the same thing.
  • Daniel Davies
    external cd-rom not a hard drive, it wont work with the external hard drive!
Error message on laptop that says boot manager is missing press ctrl alt del to restart computer
it is looking for windows boot manager need to run a repair from disc on boot
Jan 22, 2013 | Toshiba Computers & Internet
Missing boot manager and blue on everything
if you boot pressing F8 can you get to the repair option?
Nov 27, 2012 | Computers & Internet
My ntoskrnl.exe file is missing or corrupt
To repair missing system file/s orcorrupted system file/s, boot up with the Windows installation CD then -Press R to repair wheninstructed.Press 1 or Enter to repairthe C:\Windows folder.Then type chkdsk /r and then press Enter.The repair process willtake quite a long time.
May 23, 2012 | Toshiba Satellite A135-S4527 Notebook
On my Toshiba Satellite L305-S5955 (Boot Manager is missing Press Ctrl Alt*Del to restart). How do i resolve this problem?
You simply have to boot from your Windows 7 installation CD and instead of choosing install you choose repair, and then repair boot start-up, next you let it run and it will be done. Easy as pie.
Mar 12, 2012 | Computers & Internet
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Bootmgr is missing
You have formatted the HDD in another computer and the “boot manager” was destroyed.
There is no operating system on the HDD and therefore the error message: “BOOTMGR is missing Press Ctrl+Alt+Del to restart" appears
The second message “PXE-M0F: Existing PXE ROM” says that the notebook tries to boot form the LAN but it’s not able to find an OS using the LAN connection!
Why all this error messages appears?!
Well, I think the CD/DVD drive cannot read the inserted WinXP CD and therefore in switches to LAN.
Note; You can boot from the drive by pressing the “C” button immediately after notebook starting or you will press the F12 to get the booting menu. Then you could choose the ODD as booting source.
If you will be not able to boot from your WinXP CD I assume either the CD is faulty or the CD/DVD drive cannot handle this CD.
Jan 20, 2010 | Toshiba Satellite A135-S2356 Notebook
BOOTMGR is missing
If XP, boot the XP CD, go to recovery console (R at first prompt) Type the command BOOTCFG /REBUILD
Microsoft instuctions are here:
http://support.microsoft.com/kb/330184
If Vista boot to the Vista DVD, and run a startup repair per this:
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Dec 18, 2009 | Toshiba Satellite Pro L300 Notebook
Used Recovery Disk and I have an application error
It seems like your hard drive has some bad sectors.
You need to run some disk manager software to check/fix tour disk.
The best choice would be to download the "ultimate cd" from here
Boot from the cd, go to "hard disk tools" and select a disk manager (better to select the one from the same manufacturer of the disk).
Run a scan, and fix the drive (if it is possible). Then rerun your system restore cd again.
If the hard drive can't be fixed, you'll have to replace it before running the system retore.
Dec 15, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite A135-S4427 Frozen
there is problem with the mother board try repairing at repair shop
Nov 29, 2008 | Toshiba Satellite A135-S4427 Notebook
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
Toshiba Satellite P205-S6287 Notebook PC Logo
2,304 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
